    UIFlow 1.8.0
    Official Updates
    11
    31
    83.8k
    • m5stackM
      m5stack @Mati
      @mati did you open more than two UIFlow web pages? if you open two pages in the same browser and use different hardware. that would have some conflict. so I think you just need to open a new browser. it will work fine.
      MatiM 2 Replies Last reply Reply Quote 0
      • MatiM
        Mati @m5stack
        @m5stack indeed it was two tabs !
        Let me check this, thx for a hint.
        • T
          tnkmasayuki
          I can't stop the sound.
          UIFlow1.8.0 + M5StickC Plus
          • S
            stefanj9
            Wher can I find version 1.8.0?
            MatiM 1 Reply Last reply Reply Quote 0
            • MatiM
              Mati @stefanj9
              This post is deleted!
              • MatiM
                Mati @m5stack
                @m5stack hmm no luck one tab and still error
                but ... its just bug me so after listing all modules on AtomDUT its turn on you have made a typo in the from base.DTU_LoRAWAN should be base/DTU_LoRaWAN
                from base.DTU_LoRAWAN import DTU_LoRAWAN
                into
                from base.DTU_LoRaWAN import DTU_LoRaWAN
                m5stackM 1 Reply Last reply Reply Quote 0
                • P
                  plusulli
                  In the Remote+ documentation for the slider it says "click the gear button on the block to add a variable before use" But there is no gear button.
                  • m5stackM
                    m5stack @plusulli
                    @plusulli sorry. that is a mistake. draw the slider to the preview box. workspace will auto create print block and variable
                    • m5stackM
                      m5stack @Mati
                      @mati I think the module name is from base.DTU_LoRaWAN import DTU_LoRaWAN......a is lowercase
                      • MatiM
                        Mati @m5stack
                        @m5stack said in UIFlow 1.8.0:
                        This is a problem in the UiFlow, after importing lorawan init in the code we have LoRAWAN.
                        And what a supprise its fixed now ;)
                        Day ago was
                        what a nice silent fix =]
                        • P
                          plusulli
                          in the german version of UIflow Remote+ the slider function is faulty in the english version it is ok i searched for a long time until i found it0_1626729513974_slider.jpg
