    UIFlow 1.8.0
    31 Posts 11 Posters 94.1k Views 2 Watching
    • OyczEO Offline
      OyczE
      @m5stack could we get reply about uiflow support for lorawan ?
      • m5stackM Offline
        m5stack @OyczE
        @mati you could try 0001 for the mask code
        • m5stackM Offline
          m5stack @OyczE
          @mati did you open more than two UIFlow web pages? if you open two pages in the same browser and use different hardware. that would have some conflict. so I think you just need to open a new browser. it will work fine.
          OyczEO 2 Replies Last reply Reply Quote 0
          • OyczEO Offline
            OyczE @m5stack
            @m5stack indeed it was two tabs !
            Let me check this, thx for a hint.
              tnkmasayuki
              I can't stop the sound.
              UIFlow1.8.0 + M5StickC Plus
                stefanj9
                Wher can I find version 1.8.0?
                • OyczEO Offline
                  OyczE @stefanj9
                  • OyczEO Offline
                    OyczE @m5stack
                    @m5stack hmm no luck one tab and still error
                    but ... its just bug me so after listing all modules on AtomDUT its turn on you have made a typo in the from base.DTU_LoRAWAN should be base/DTU_LoRaWAN
                    from base.DTU_LoRAWAN import DTU_LoRAWAN
                    into
                    from base.DTU_LoRaWAN import DTU_LoRaWAN
                      plusulli
                      In the Remote+ documentation for the slider it says "click the gear button on the block to add a variable before use" But there is no gear button.
                      • m5stackM Offline
                        m5stack @plusulli
                        @plusulli sorry. that is a mistake. draw the slider to the preview box. workspace will auto create print block and variable
                        • m5stackM Offline
                          m5stack @OyczE
                          @mati I think the module name is from base.DTU_LoRaWAN import DTU_LoRaWAN......a is lowercase
                          • OyczEO Offline
                            OyczE @m5stack
                            @m5stack said in UIFlow 1.8.0:
                            This is a problem in the UiFlow, after importing lorawan init in the code we have LoRAWAN.
                            And what a supprise its fixed now ;)
                            Day ago was
                            what a nice silent fix =]
                              plusulli
                              in the german version of UIflow Remote+ the slider function is faulty in the english version it is ok i searched for a long time until i found it0_1626729513974_slider.jpg
