    M5ez, a complete interface builder system for the M5Stack as an Arduino library. Extremely easy to use.
    PROJECTS
    22
    95
    697.2k
    • RopR
      Rop @BrianR
      @brianr It depends on the rest of your program, but normally you would place it in setup(). Then make sure the event function returns 1 to run as often as possible. What that means is that you cannot provide Blynk.run() directly but must make your own function that runs Blynk.run() and returns a uint16_t of value 1
      This needs to be more convenient, I know. addEvent() needs another go-over, better documentation and examples, will put that on the list.
      B 1 Reply Last reply Reply Quote 0
      • B
        BrianR @Rop
        Ah yes, success! I added ez.addEvent(run_Blynk); to the setup(), and then created a function down below, after the loop, that looks like the following. It's worth noting that I'm using the M5 as a "receiver" from a bridge, thus the blynk_write(V1) statement.
        uint16_t run_Blynk() {
          Blynk.run();
          return 1;
        BLYNK_WRITE(V1){
            eventData = param.asString();
        That did the trick, Blynk connects and stays connected. Now trying to figure out how to display the dynamic data from Blynk on the canvas. If I figure this all out, I'll write a short demo in a new topic for others, as I haven't seen many examples of actual use of M5ez, other than the demo program, but most projects are more than just menus, they have to display something... Again, @rop, excellent work, and thanks again so much!
        asalazaroA 1 Reply Last reply Reply Quote 0
        • B
          bobolink
          I really like M5ez so I gave it its own core. Justified it by saying that’s real MVC architecture! Real Computer Science stuff.
          GLOBAL INFO
          core 0 is the communications processor.
          Uses the ESP-NOW protocol
          on the 2.4 GHz radio
          This process runs as a task created
          on core 1
          core 1 is the UI processor.
          Maintains the M5Stack M5ez LCD menu
          Runs Arduino setup() and loop()
          Use RTOS semaphores when accessing the global vars to/from the local versions.
          • M
            macle
            Hello,
            Is there a chance to change font (or size) of ez.header ?
            Regards, M
            • M
              mawg
              Looks great! Does it play well with PlatformIO ?
              • m5stackM
                m5stack
                Great Job
                • ajb2k3A
                  ajb2k3
                  @Rop is M5EZ supporting the Stick C?
                  I have had a query from the Facebook group.
                  • RopR
                    Rop
                    @ajb2k3
                    No it does not: it only works on the 3-Button M5Stack devices.
                    • ajb2k3A
                      ajb2k3 @Rop
                      @rop Any intention of a stick version?
                      • asalazaroA
                        asalazaro @BrianR
                        @brianr @rop Hey guys, thanks a lot for this very elegant solution, I´m using the ezMenu library in a program where I had installed Blynk working very well but everytime when I activated the ezMenu with mainmenu.run(); my Blynk app was very unstable, with the trick of ez.addEvent(run_Blynk) in the setup() function now is working very well, thanks for the help
                        • H
                          hobo
                          Hi,
                          great project.
                          It is possible to use the face encoder for up, down and enter?
                          if yes, you have an example?
                          this will be great
                          • H
                            hobo
                            This post is deleted!
                            • G
                              GSAL
                              Hi,
                              It is great using the M5EZ!
                              But I want / need to give my Core a static IP address. Is there an easy way to alter the Wifi settings menu and add the option of adding static ip? Maybe In such a way it is stored in the preferences?
                              kr, G
                              • K
                                kilam
                                Hi,
                                I wanted to know if there is a way to use faces keyboard in the menus (i.e. I have the calculator keyboard and instead of using the three buttons to go up and down and select, I want to use the keys on the face, for example for selecting first line I will type on the key '1' and so on).
                                and if it is possible, can you give me an example of code using it.
                                Thanks
                                • A
                                  AndyT
                                  How do i get the characters for my region such as the pound sign £ ?
