    M5Stack MultiApp Advanced Firmware
    PROJECTS
    14
    51
    338.7k
    • P
      picpic020960
      Calin
      first compil :
      src\Apps\WiFiWps\WpsConnect.cpp:73:16: error: no match for 'operator=' (operand types are 'esp_wps_config_t' and '<brace-enclosed initializer list>')
      some mistake ?
      edit :
      commented ==> Build OK
      but how to load the firmware in the m5stack ?
      other question : how to apply the patch ?
      thanks for help
      Regards
      C 1 Reply Last reply Reply Quote 0
      • C
        Calin @picpic020960
        @picpic020960 在 M5Stack MultiApp Advanced Firmware 中说:
        Calin
        first compil :
        some mistake ?
        No. There is no mistake.
        PlatformIO updated the Arduino-ESP32 framework to new version.
        I updated the MultiApp firmware to work with this new version.
        If you use git, just pull the latest commit from github and recompile.
        If not, download the repository again then compile.
        edit :
        Please READ the repository instructions !
        The old patch is no longer needed... because Espressif fixed the GPIO39 bug on the latest arduino-esp32 framework.
        • P
          picpic020960
          Hi Calin
          when m5stack not connected i see ' <version....py>' at end of build report.
          (from memory , now at work , not at home)
          when m5stack connected i see nothing at end of build report.
          i have com1 and com4. how to choose ?
          thanks for help
          Regards
          • C
            Calin @picpic020960
            Hi Calin
            thanks for help
            Regards
            You don't have to chose anything.
            No need to select the upload port.
            PlatformIO will detect the M5Stack port automatically, once is connected to PC USB.
            • KabronK
              Kabron
              New version compilation results:
              M5StackMod initializing...[E][sd_diskio.cpp:739] sdcard_mount(): f_mount failed 0x(3)
              E (705) SPIFFS: mount failed, -10025
              [E][SPIFFS.cpp:47] begin(): Mounting SPIFFS failed! Error: -1
              OK
              [E][Preferences.cpp:330] getUShort(): nvs_get_u16 fail: light NOT_FOUND
              and nothing more...
              any ideas?
              • C
                Calin @Kabron
                @kabron 在 M5Stack MultiApp Advanced Firmware 中说:
                OK
                and nothing more...
                any ideas?
                Please update the Espressif 32 platform to latest version (v1.1.1 at this moment)
                That should solve the problem.
                KabronK 1 Reply Last reply Reply Quote 0
                • KabronK
                  Kabron @Calin
                  @calin 在 M5Stack MultiApp Advanced Firmware 中说:
                  I have 1.1.2 installed and do not know how to degrade
                  P.S.
                  degrade with
                  platform = espressif32@1.1.1
                  and now it works
                  • C
                    Calin @Kabron
                    P.S.
                    degrade with
                    and now it works
                    I just tested with espressif32 V1.1.2 and work's just fine.
                    Please download the latest repository commit and compile.
                    it should work just fine.
                    • R
                      Rodlenz
                      Hi Calin, thanks for this amazing work. How I can add my own code/Application? Tks in advance for any help you can provide. brgds.
                      ? 1 Reply Last reply Reply Quote 0
                        A Former User @Rodlenz
                        Hi
                        somebody make a test with Netatmo ?
                        I would like to be sure before start this install to see if there are possibility to connect via API key to netatmo server.
                        interest by this
                        Thx
                        • B
                          brianbgarber
                          Hello, I realize this topic is very old but I'm trying to compile the MultiApp Advanced firmware. I'm getting several compile issues:
                          1. src/Apps/WiFiWps/WpsConnect.cpp:30:12: error: 'struct esp_wps_config_t' has no member named 'crypto_funcs'
                          2. src/Apps/WiFiWps/WpsConnect.cpp:30:28: error: 'g_wifi_default_wps_crypto_funcs' was not declared in this scope
                          3. src/Apps/WiFiWps/WpsConnect.cpp:90:27: error: no matching function for call to 'onEvent(void (&)(arduino_event_id_t, system_event_info_t))'
                          4. src/Apps/WiFiWps/WpsConnect.cpp:90:18: error: invalid conversion from 'void ()(arduino_event_id_t, system_event_info_t)' to 'WiFiEventSysCb' {aka 'void ()(arduino_event_t*)'} [-fpermissive]
                          5. *** [.pio\build\esp-wrover-kit\src\Apps\WiFiWps\WpsConnect.cpp.o] Error 1
                          6. lib/ESP32Audio/src/AudioOutputI2S.cpp:190:10: error: 'i2s_write_bytes' was not declared in this scope
                          7. *** [.pio\build\esp-wrover-kit\lib803\ESP32Audio\AudioOutputI2S.cpp.o] Error 1
                          I did clone the git repo today, so everything should be up to date. Looks like I'm missing some library?
                          Thanks,
                          Brian
                          1 Reply Last reply Reply Quote 3
