    51 Posts 14 Posters 361.3k Views 7 Watching
      Calin @picpic020960
      @picpic020960 在 M5Stack MultiApp Advanced Firmware 中说:
      no is straight forward with corporate proxy !
      Well... yeah... you are right on this one...
      [pre-compiled firmware is best for MultiApp popularity]
      thanks
      Ok... i will bring it back later today...
        picpic020960
        Hi Calin
        tested last night ! sync , download , finish , reset and ... black screen
        maybe my error : use the old [not Advanced] FLASH_DOWNLOAD_TOOLS_V3.6.4.zip
        other way : 'old MultiApp' is OK without SD card and no jpg , maybe 'Advanced' no ?
        more : windows 10 (on thomson tablet)
        my fear :have bad clone !
        I test again tonight
        Regards
          Calin @picpic020960
          Hi Calin
          Regards
          As i told you... the best solution is to COMPILE the project on PlatformIO.
          The M5Stack came with default factory partitions table.
          That partition table is incompatible with MultiApp-Advanced firmware.
          Old MultiApp firmware use standard partitions table and that's why that precompiled binary work.
          The precompiled firmware only write the application data. So precom piled binary will be useful only if you try to update the multiapp-advanced firmware to a newer version.
          Will NOT work if you try to write the multiapp-advanced over a different application.
          On MultiApp-advanced i use a custom partition table that is written if you compile and upload the project from PlatformIO.
            picpic020960
            Hi Calin , OK
            Download (and unzip) this repository ==> OK
            Download and Install Visual Studio Code https://code.visualstudio.com/ ==>OK
            Install the PlatformIO Extension ==> OK
            Install ESP32 Framework on PlatformIO ==> How TO ? no link and a lot of ESP32 framework
            thanks for help
            Regards
              Calin @picpic020960
              Hi Calin , OK
              thanks for help
              Regards
              Go to Platforms
              Type in ESP32 on the search bar
              Click on Espressif 32
              Click INSTALL
              Wait to finish (this may take 1 - 5 minutes, depending on your internet connection speed)
              Done.
              To open MultiApp Advanced project:
              right click on the project folder
              Select "Open in VsCode"
              VsCode will open and the project will be loaded in PlatformIO
              You don't need to install any library to compile the MultiApp-Advanced. All necessary resources are included into project.
                picpic020960
                Calin
                first compil :
                src\Apps\WiFiWps\WpsConnect.cpp:73:16: error: no match for 'operator=' (operand types are 'esp_wps_config_t' and '<brace-enclosed initializer list>')
                some mistake ?
                edit :
                commented ==> Build OK
                but how to load the firmware in the m5stack ?
                other question : how to apply the patch ?
                thanks for help
                Regards
                  Calin @picpic020960
                  Calin
                  first compil :
                  some mistake ?
                  No. There is no mistake.
                  PlatformIO updated the Arduino-ESP32 framework to new version.
                  I updated the MultiApp firmware to work with this new version.
                  If you use git, just pull the latest commit from github and recompile.
                  If not, download the repository again then compile.
                  edit :
                  Please READ the repository instructions !
                  The old patch is no longer needed... because Espressif fixed the GPIO39 bug on the latest arduino-esp32 framework.
                    picpic020960
                    Hi Calin
                    when m5stack not connected i see ' <version....py>' at end of build report.
                    (from memory , now at work , not at home)
                    when m5stack connected i see nothing at end of build report.
                    i have com1 and com4. how to choose ?
                    thanks for help
                    Regards
                      Calin @picpic020960
                      Hi Calin
                      thanks for help
                      Regards
                      You don't have to chose anything.
                      No need to select the upload port.
                      PlatformIO will detect the M5Stack port automatically, once is connected to PC USB.
                      • KabronK Offline
                        Kabron
                        New version compilation results:
                        M5StackMod initializing...[E][sd_diskio.cpp:739] sdcard_mount(): f_mount failed 0x(3)
                        E (705) SPIFFS: mount failed, -10025
                        [E][SPIFFS.cpp:47] begin(): Mounting SPIFFS failed! Error: -1
                        OK
                        [E][Preferences.cpp:330] getUShort(): nvs_get_u16 fail: light NOT_FOUND
                        and nothing more...
                        any ideas?
                          Calin @Kabron
                          @kabron 在 M5Stack MultiApp Advanced Firmware 中说:
                          OK
                          and nothing more...
                          any ideas?
                          Please update the Espressif 32 platform to latest version (v1.1.1 at this moment)
                          That should solve the problem.
                          • KabronK Offline
                            Kabron @Calin
                            @calin 在 M5Stack MultiApp Advanced Firmware 中说:
                            I have 1.1.2 installed and do not know how to degrade
                            P.S.
                            degrade with
                            platform = espressif32@1.1.1
                            and now it works
                              Calin @Kabron
                              P.S.
                              degrade with
                              and now it works
                              I just tested with espressif32 V1.1.2 and work's just fine.
                              Please download the latest repository commit and compile.
                              it should work just fine.
                                Rodlenz
                                Hi Calin, thanks for this amazing work. How I can add my own code/Application? Tks in advance for any help you can provide. brgds.
                                ? 1 Reply Last reply Reply Quote 0
                                • ? Offline
                                  A Former User @Rodlenz
                                  Hi
                                  somebody make a test with Netatmo ?
                                  I would like to be sure before start this install to see if there are possibility to connect via API key to netatmo server.
                                  interest by this
                                  Thx
                                  • B Offline
                                    brianbgarber
                                    Hello, I realize this topic is very old but I'm trying to compile the MultiApp Advanced firmware. I'm getting several compile issues:
                                    1. src/Apps/WiFiWps/WpsConnect.cpp:30:12: error: 'struct esp_wps_config_t' has no member named 'crypto_funcs'
                                    2. src/Apps/WiFiWps/WpsConnect.cpp:30:28: error: 'g_wifi_default_wps_crypto_funcs' was not declared in this scope
                                    3. src/Apps/WiFiWps/WpsConnect.cpp:90:27: error: no matching function for call to 'onEvent(void (&)(arduino_event_id_t, system_event_info_t))'
                                    4. src/Apps/WiFiWps/WpsConnect.cpp:90:18: error: invalid conversion from 'void ()(arduino_event_id_t, system_event_info_t)' to 'WiFiEventSysCb' {aka 'void ()(arduino_event_t*)'} [-fpermissive]
                                    5. *** [.pio\build\esp-wrover-kit\src\Apps\WiFiWps\WpsConnect.cpp.o] Error 1
                                    6. lib/ESP32Audio/src/AudioOutputI2S.cpp:190:10: error: 'i2s_write_bytes' was not declared in this scope
                                    7. *** [.pio\build\esp-wrover-kit\lib803\ESP32Audio\AudioOutputI2S.cpp.o] Error 1
                                    I did clone the git repo today, so everything should be up to date. Looks like I'm missing some library?
                                    Thanks,
                                    Brian
