    M5StickC: turn off screen completely
    M5 Stick/StickC
    11
    25
    101.8k
    • M
      Multihelix @maxstack
      @maxstack - Yes, I used ESP DeepSleep set to wake on Button A being pressed, but I would say that the 5 hour time was not under ideal conditions, as I occasionally woke up the device to confirm it was still working and to check the time - a resonable activity for a watch.
      S 1 Reply Last reply Reply Quote 0
      • S
        spiffmonious @Multihelix
        @multihelix Can you post a link to your watch code?
        • K
          klimbot @dda
          @dda said in M5StickC: turn off screen completely:
          I did a simple test: with only REG 28H the screen stays slightly warm. With both 28H and 10H, the screen cools off after a while. Hardly a scientific test, I know, but seems to point to the need to set both registers.
          I'm looking at this thread to hopefully implement a complete screen turn off, but am not sure what register mask to use (based on quoted post)
          Here is what I have, the screen is off but hard to know if the screen has actually been disabled.
          void turnOffScreen() {
          Wire1.beginTransmission(0x34);
          Wire1.write(0x10);
          Wire1.write(0b00000000); // 7-3=? | 2=EXTEN | 1=? | 0=DC-DC2
          Wire1.endTransmission();
          Wire1.begin(21, 22);
          Wire1.write(0x12);
          Wire1.write(0b01001011); // 7=? | 6=EXTEN | 5=? | 4=DC-DC2 | 3=LDO3 | 2=LDO2 | 1=DC-DC3 | 0=DC-DC1
          Wire1.write(0x28);
          Wire1.write(0b00001111); // 7-4=LDO2 | 3-0=LDO3
          • F
            ForestRupicolous
            @klimbot: I think you have to turn LDO3 and LDO2 off, in your code only LDO2 is off. Take a look at this picture: https://docs.m5stack.com/assets/img/product_pics/core/minicore/m5stickc/m5stickc_05.webp
            • V
              viandou
              This is how I init my M5StickC in a full black screen way.
              M5.begin(0,1,1);
              M5.Axp.SetLDO2(false);
              M5.Axp.SetLDO3(false);
