    Sim800l
    PRODUCTS
    8
    13
    35.2k
    • J
      jpilarski
      Re: Sim800l module
      I can't seem to find any documentation on the use of this module. Can you please provide an example file showing the supported AT commands. Also I can't find any information on the pinout for this board. From a users perspective it really is unfortunate to buy a product and struggle to figure how to use it. The m5stack, up to this point, was a terrific experience because you guys had samples and drawings and solid documentation. In the future I suggest only releasing modules once they are fully documented.
      JJJ W 2 Replies Last reply Reply Quote 0
      • JJJ
        JJ @jpilarski
        @jpilarski Hi Jp,
        Not sure where you purchased yours but they should have included the photo below outlining the pin-outs used.
        Here is a link to a manual for the AT command set for this sim module:
        https://cdn-shop.adafruit.com/datasheets/sim800_series_at_command_manual_v1.01.pdf
        There are many more datasheets at the Simcom website link if you are prepared to register:
        http://simcomm2m.com/En/module/detail.aspx?id=138
        Here is a link to a simple program that could form the basis for use with the M5 stack.... You can probably find more examples on github.
        http://www.ayomaonline.com/programming/quickstart-sim800-sim800l-with-arduino/
        It will need some conversion to make it compatible with the M5Stack. For starters you would need to add this to the start:
        #include <M5Stack.h>
        The GSM format used on this module is not supported in my country so I have no experience using it.
        Good luck.
        • X
          X-Dron
          If you can Russian the best manual for SIM800L here
          http://codius.ru/articles/GSM_модуль_SIM800L_часть_1
          Many sketches for Arduino that can be easily conversion to M5 Stask.
          Just replace
          #include <SoftwareSerial.h>
          SoftwareSerial SIM800 (8, 9); // 8 - RX Arduino (TX SIM800L), 9 - TX Arduino (RX SIM800L)
          to
          HardwareSerial SIM800 (2); // pin 16 = RX, pin 17 = TX
          for example
          https://yadi.sk/d/SxWs6t0x3UBco6
          • J
            jpilarski
            Thanks very much. Is the mic on GPIO5. I was just making a purchase on amazon and thought I'd try out a module. This image wasn't on the re-sellers page. I wasn't even sure what it did and figured it would be a new thing to learn about. Really your documentation has been really great. It makes a huge difference to users. The enjoyable experience of using your product is what made me want to purchase a module. Maybe there should be a page for each module with all the relevant information just in case the re-seller isn't providing it.
            • X
              X-Dron @jpilarski
              @jpilarski 在 Sim800l 中说:
              Is the mic on GPIO5
              No. mic and headphone are connected direct to SIM800L module.
              GPIO5 is reset.
              alt text
              Interconnection
              M5 Stask <> SIM800L
              Vbat - Vcc (3.7-4.3V)
              GPIO16(RX) - TXD
              GPIO17(TX) - RXD (must be not direct 3.3V > 2.5V)
              GPIO5 - RST
              GND - GND
              RING is not used.
              DTR is not used.
              MIC+, MIC- to microphone.
              SPK+, SPK- to headphone.
              Example for Arduino
              • J
                Jp
                Hello
                any update of demonstration source code for the sim module with realtime streaming audio over Gsm ?
                Looking for using it as a basic talking only smartphone in full duplex, send and receive at the same time ?
                If possible Under Arduino IDE , with ino file ...
                Good project and information..
                Great day.
                Jp
                • J
                  Jp
                  if it can help you :
                  http://miliohm.com/sim800l-arduino-tutorial/
                  Br
                  Jp
                  • W
                    wschnell @jpilarski
                    Just found an important fact that's mentioned nowhere: there are 2 ways to insert the SIM Card (uhm, maybe four …). Note that one corner is cut off. This does NOT go in first. When you put in the SIM Card, it will look towards your right hand.
                    Now the AT commands work ...
                    • W
                      wschnell @wschnell
                      HardwareSerial Serial2(2);
                      M5.Lcd.printf("GSM Test"); // just to see that the program has started
                      Serial.begin(115200); // switch on the serial "terminal" of Arduino IDE
                      // Serial2.begin(unsigned long baud, uint32_t config, int8_t rxPin, int8_t txPin, bool invert)
                      Serial2.begin(9600, SERIAL_8N1, 16, 17); // 9600 baud seems to be the default for modems; pins as printed on the PCB board
                      at("", 200);
                      at("Z", 200); // reset all parameters to the user defined profile
                      at("I", 200); // display product info
                      at("+CPIN?", 200); // unlocked ?
                      at("+CGREG?", 200); // check the registration status of the device
                      at("+COPS?", 2000); // get operator
                      at("+CSQ", 200); // check signal quality
                      at("+CNUM?", 200); // find phone number of the device
                      at("+CNUM", 2000); // find phone number of the device
                      at("+ATS0=3", 200); // answer incoming calls after 1 ring tone(s)
                      at("+CREG=1", 200);
                      at("+CREG?", 200);
                      at("+CFUN=?", 200); // list functionality levels
                      at("+CFUN=1", 200); // set to full functionality
                      // at("+COPS=1,0,"E-Plus"", 200);
                      at("+CR=?", 200); // service reporting control
                      at("+CGATT=?", 200);
                      at("+CGATT=1", 200);
                      Serial2.printf("AT+CSTT="%s","%s","%s"\r\n", apn, user, pass);
                      delay(200);
                      Serial.print(Serial2.readString());
                      at("+ICCID", 200);
                      at("+GSN", 200);
                      at("+CIICR", 200);
                      at("+CIFSR", 200);
                      at("+CPOL?", 200);
                      at("+COPS=?", 2000); // get operators
                      void at(char* sCmd, unsigned long lDelay) {
                      Serial2.printf("AT%s\r\n", sCmd);
                      delay(lDelay);
                      // now that the intro is done, we go into an interactive loop, where we can enter AT commands or press a button to do something
                      if(Serial.available()) {
                      int ch = Serial.read();
                      Serial2.write(ch);
                      M5.Lcd.write(ch);
                      if(Serial2.available()) {
                      int ch = Serial2.read();
                      Serial.write(ch);
                      if (M5.BtnA.wasPressed()) {
                      M5.Lcd.printf("\nhangup");
                      at("H", 200); // hangup
                      if (M5.BtnB.wasPressed()) {
                      M5.Lcd.printf("\ndialing");
                      at("L8", 200); // volume 0-9
                      at("D0043xxxxxxxx;", 2000); // dial
                      if (M5.BtnC.wasPressed()) {
                      M5.Lcd.printf("\nsms");
                      at("+CMGF=1", 200); // set the GSM Module to text mode
                      at("+CMGS="+43xxxxxxxxxx"\rTest SMS by Walter\x1A", 2000); // sms
                      M5.update();
                      • W
                        wschnell @wschnell
                        the code above works with my SIM800L module.
                        not all is necessary, but maybe helpful …
                        what I have learned up to now:
                        • it works with HardwareSerial; no libraries to declare; default pins
                        • I can make phone calls
                        • I can send and receive SMS
                        • the audio of the phone is not connected to the M5Stack; it's just the bare minimum.
                        • if required, I might connect a better antenna - there is a connector on the SIM800L module and a hole in the base module I could use.
                        • no soldering, no cables, no voltage problems
                        • no EDGE, no LTE
                        • the LED on the SIM800L module can be seen through the headphone hole.
                        • the Arduino IDE installation brings a GSM library, but it is not listed under examples in the IDE.
                        bye for now
                        Walter
                        • MrTarantlM
                          MrTarantl
                          I suggest to use the TinyGSM library (tested and it works)
                          https://github.com/vshymanskyy/TinyGSM
                          in the example sketches simply change serial1 to serial2
                          :D
                          Don't just talk... create and make
                          • C
                            cepics @wschnell
                            @wschnell Hi, sorry for the late response...;-)
                            I'm trying your code but Arduino doesn't compile with this error:
                            Compilation error: 's' was not declared in this scope
                            about this line:
                            no way to work with SIM800L MODULE!!
                            tips??
                              felmue @cepics
                              Hello @cepics
                              try changing the line to:
                              Serial2.printf("AT+CSTT=\"%s\",\"%s\",\"%s\"\r\n", apn, user, pass);
