    Sim800l
    13 Posts 8 Posters 40.1k Views 2 Watching
    • JJJ Offline
      JJ @jpilarski
      @jpilarski Hi Jp,
      Not sure where you purchased yours but they should have included the photo below outlining the pin-outs used.
      Here is a link to a manual for the AT command set for this sim module:
      https://cdn-shop.adafruit.com/datasheets/sim800_series_at_command_manual_v1.01.pdf
      There are many more datasheets at the Simcom website link if you are prepared to register:
      http://simcomm2m.com/En/module/detail.aspx?id=138
      Here is a link to a simple program that could form the basis for use with the M5 stack.... You can probably find more examples on github.
      http://www.ayomaonline.com/programming/quickstart-sim800-sim800l-with-arduino/
      It will need some conversion to make it compatible with the M5Stack. For starters you would need to add this to the start:
      #include <M5Stack.h>
      The GSM format used on this module is not supported in my country so I have no experience using it.
      Good luck.
      • X Offline
        X-Dron
        If you can Russian the best manual for SIM800L here
        http://codius.ru/articles/GSM_модуль_SIM800L_часть_1
        Many sketches for Arduino that can be easily conversion to M5 Stask.
        Just replace
        #include <SoftwareSerial.h>
        SoftwareSerial SIM800 (8, 9); // 8 - RX Arduino (TX SIM800L), 9 - TX Arduino (RX SIM800L)
        to
        HardwareSerial SIM800 (2); // pin 16 = RX, pin 17 = TX
        for example
        https://yadi.sk/d/SxWs6t0x3UBco6
          jpilarski
          Thanks very much. Is the mic on GPIO5. I was just making a purchase on amazon and thought I'd try out a module. This image wasn't on the re-sellers page. I wasn't even sure what it did and figured it would be a new thing to learn about. Really your documentation has been really great. It makes a huge difference to users. The enjoyable experience of using your product is what made me want to purchase a module. Maybe there should be a page for each module with all the relevant information just in case the re-seller isn't providing it.
          • X Offline
            X-Dron @jpilarski
            @jpilarski 在 Sim800l 中说:
            Is the mic on GPIO5
            No. mic and headphone are connected direct to SIM800L module.
            GPIO5 is reset.
            alt text
            Interconnection
            M5 Stask <> SIM800L
            Vbat - Vcc (3.7-4.3V)
            GPIO16(RX) - TXD
            GPIO17(TX) - RXD (must be not direct 3.3V > 2.5V)
            GPIO5 - RST
            GND - GND
            RING is not used.
            DTR is not used.
            MIC+, MIC- to microphone.
            SPK+, SPK- to headphone.
            Example for Arduino
              Jp
              Hello
              any update of demonstration source code for the sim module with realtime streaming audio over Gsm ?
              Looking for using it as a basic talking only smartphone in full duplex, send and receive at the same time ?
              If possible Under Arduino IDE , with ino file ...
              Good project and information..
              Great day.
              Jp
                Jp
                if it can help you :
                http://miliohm.com/sim800l-arduino-tutorial/
                Br
                Jp
                • W Offline
                  wschnell @jpilarski
                  Just found an important fact that's mentioned nowhere: there are 2 ways to insert the SIM Card (uhm, maybe four …). Note that one corner is cut off. This does NOT go in first. When you put in the SIM Card, it will look towards your right hand.
                  Now the AT commands work ...
                  • W Offline
                    wschnell @wschnell
                    HardwareSerial Serial2(2);
                    M5.Lcd.printf("GSM Test"); // just to see that the program has started
                    Serial.begin(115200); // switch on the serial "terminal" of Arduino IDE
                    // Serial2.begin(unsigned long baud, uint32_t config, int8_t rxPin, int8_t txPin, bool invert)
                    Serial2.begin(9600, SERIAL_8N1, 16, 17); // 9600 baud seems to be the default for modems; pins as printed on the PCB board
                    at("", 200);
                    at("Z", 200); // reset all parameters to the user defined profile
                    at("I", 200); // display product info
                    at("+CPIN?", 200); // unlocked ?
                    at("+CGREG?", 200); // check the registration status of the device
                    at("+COPS?", 2000); // get operator
                    at("+CSQ", 200); // check signal quality
                    at("+CNUM?", 200); // find phone number of the device
                    at("+CNUM", 2000); // find phone number of the device
                    at("+ATS0=3", 200); // answer incoming calls after 1 ring tone(s)
                    at("+CREG=1", 200);
                    at("+CREG?", 200);
                    at("+CFUN=?", 200); // list functionality levels
                    at("+CFUN=1", 200); // set to full functionality
                    // at("+COPS=1,0,"E-Plus"", 200);
                    at("+CR=?", 200); // service reporting control
                    at("+CGATT=?", 200);
                    at("+CGATT=1", 200);
                    Serial2.printf("AT+CSTT="%s","%s","%s"\r\n", apn, user, pass);
                    delay(200);
                    Serial.print(Serial2.readString());
                    at("+ICCID", 200);
                    at("+GSN", 200);
                    at("+CIICR", 200);
                    at("+CIFSR", 200);
                    at("+CPOL?", 200);
                    at("+COPS=?", 2000); // get operators
                    void at(char* sCmd, unsigned long lDelay) {
                    Serial2.printf("AT%s\r\n", sCmd);
                    delay(lDelay);
                    // now that the intro is done, we go into an interactive loop, where we can enter AT commands or press a button to do something
                    if(Serial.available()) {
                    int ch = Serial.read();
                    Serial2.write(ch);
                    M5.Lcd.write(ch);
                    if(Serial2.available()) {
                    int ch = Serial2.read();
                    Serial.write(ch);
                    if (M5.BtnA.wasPressed()) {
                    M5.Lcd.printf("\nhangup");
                    at("H", 200); // hangup
                    if (M5.BtnB.wasPressed()) {
                    M5.Lcd.printf("\ndialing");
                    at("L8", 200); // volume 0-9
                    at("D0043xxxxxxxx;", 2000); // dial
                    if (M5.BtnC.wasPressed()) {
                    M5.Lcd.printf("\nsms");
                    at("+CMGF=1", 200); // set the GSM Module to text mode
                    at("+CMGS="+43xxxxxxxxxx"\rTest SMS by Walter\x1A", 2000); // sms
                    M5.update();
                    • W Offline
                      wschnell @wschnell
                      the code above works with my SIM800L module.
                      not all is necessary, but maybe helpful …
                      what I have learned up to now:
                      • it works with HardwareSerial; no libraries to declare; default pins
                      • I can make phone calls
                      • I can send and receive SMS
                      • the audio of the phone is not connected to the M5Stack; it's just the bare minimum.
                      • if required, I might connect a better antenna - there is a connector on the SIM800L module and a hole in the base module I could use.
                      • no soldering, no cables, no voltage problems
                      • no EDGE, no LTE
                      • the LED on the SIM800L module can be seen through the headphone hole.
                      • the Arduino IDE installation brings a GSM library, but it is not listed under examples in the IDE.
                      bye for now
                      Walter
                      • MrTarantlM Offline
                        MrTarantl
                        I suggest to use the TinyGSM library (tested and it works)
                        https://github.com/vshymanskyy/TinyGSM
                        in the example sketches simply change serial1 to serial2
                        :D
                        Don't just talk... create and make
                          cepics @wschnell
                          @wschnell Hi, sorry for the late response...;-)
                          I'm trying your code but Arduino doesn't compile with this error:
                          Compilation error: 's' was not declared in this scope
                          about this line:
                          no way to work with SIM800L MODULE!!
                          tips??
                            felmue @cepics
                            Hello @cepics
                            try changing the line to:
                            Serial2.printf("AT+CSTT=\"%s\",\"%s\",\"%s\"\r\n", apn, user, pass);
