    M5StickC and Grove-Temperature_Sensor_V1.2
    4 Posts 2 Posters 6.6k Views 1 Watching
      fsidders
      I bought the Grove-Temperature_Sensor_V1.2 and connected to M5StickC. I copied almost all the code from the Seedstudio page (https://wiki.seeedstudio.com/Grove-Temperature_Sensor_V1.2/#software) to convert the analog read to actual temperature, only adding the #include <M5StickC.h> and the M5.begin, but the temperature is way off and very oscillating. I am using pin 32 to read the data, Is it correct? Is it a sensor issue?
      For example, a sample output is:
      -0.34
      -2.32
      -4.34
      -2.16
      -3.89
      -4.04
      -3.42
      -5.16
      -4.42
      -4.79
      -5.24
      -5.09
      -5.38
      -6.61
      -6.40
      -5.82
      -6.96
      -6.82
      -6.96
      -6.89
      -6.96
      -7.17
      -6.96
      -8.08
      -6.96
      -6.96
      -7.94
      And the code is:
      #include <math.h>
      const int B = 4275;
      const float R0 = 100000;
      const int PIN = 32;
      Serial.begin(115200);
      int a = analogRead(PIN);
      float R = 1023.0/a-1.0;
      R = R0*R;
      float temperature = 1.0 / (log(R / 10000.0) / B + 1 / 298.15) - 273.15;
      Serial.println(temperature);
      delay(500);
      Thanks,
      Fernando Gonzalez Sidders
        fsidders @fsidders
        @fsidders I fixed the code, changed 10000 to 100000 in temperature formula, but the temperature is still off and oscillating:
        #include <math.h>
        const int B = 4275; // B value of the thermistor
        const int PIN = 32;
        Serial.begin(9600);
        R = R0*R;
        float temperature = 1.0/(log(R/R0)/B+1/298.15)-273.15; // convert to temperature via datasheet
        delay(500);
        The temperature displayed now is:
        42.42
        44.15
        42.42
        42.85
        42.96
        45.96
        46.07
        44.38
        44.15
        42.74
        43.50
        42.42
        44.15
        44.49
        42.42
        45.16
        49.58
        42.85
        • m5stackM Online
          m5stack @fsidders
          i have check the prodcut document.then i find this information, i guess this sensor need calibration:
          Nominal B-Constant: 4250 ~ 4299K
          if still can't work normal. maybe you could try to contact seeed store
          https://wiki.seeedstudio.com/Grove-Temperature_Sensor_V1.2/#specifications
            fsidders
            I solved the issue, I am getting the correct temperature now.
            I changed the code to:
            #include <math.h>
            const int B = 4275;
            const int PIN = 33;
            float R = 4095.0/a-1.0;
            R = R0*R;
            float temperature = 1.0 / (log(R / R0) / B + 1 / 298.15) - 273.15;
            delay(500);
            The correct pin was 33, and modified the 1023.0 to 4095.0 in the formula because esp32 is returning values between 0 and 4096. But anyway, the temperature readings were too high. Then, I modified the grove cable (as is explained here https://tinkerfarm.net/projects/the-m5stickc/the-5-volt-danger-with-the-m5stickc/) feeding the temperature sensor with 3.3v instead of 5v. And, now, (with no additional code changes) the temperature is correct.
