M5StickC and ENV II Unit?(SOLVED)
I realize that the ENV hat is available, but it won't work for my purposes which require that the stick and temperature probe be in different locations. Right now, I have a solution that's working fine with the original ENV unit. But when I attempt to change to ENV II in UIFlow, it shows this unit as not working with the M5StickC.
Considering the unavailable of the original ENV unit, am I simply out of luck? Or is this a matter of waiting for a UIFlow update?
It seems I've answered my own question. By switching over to the "beta" version of UIFlow, it appears that ENV II is available, so will be supported in upcoming versions.
Mark it closed!
