    TAIL485
    4 Posts 3 Posters 9.5k Views 1 Watching
      cepics
      hi all,
      I'm reading a serial machine data out , on ATOM, with this RS422/TTL YL-128 adaptor
      datasheet
      with this code
        Serial.begin(115200);
        delay(1000);
      //              speed, mode,      rx, tx
        Serial2.begin(9600, SERIAL_8N1, 26, 32);
        delay(1000);
        recvBytesWithStartEndMarkers();
        showNewData();
      void recvBytesWithStartEndMarkers() {
        static boolean recvInProgress = false;
        static byte ndx = 0;
        byte startMarker = 0x7C; // "|"
        byte endMarker = 0x0A; // (LF) "/n"
        //  byte startMarker = 0x0A; // "/n"
        //  byte endMarker = 0x0D; // (CR) "/r"
        byte rb;
        while (Serial2.available() > 0 && newData == false) {
          rb = Serial2.read();
          if (recvInProgress == true) {
            if (rb != endMarker) {
              receivedBytes[ndx] = rb;
              ndx++;
              if (ndx >= numBytes) {
                ndx = numBytes - 1;
            else {
              receivedBytes[ndx] = '\0'; // terminate the string
              numReceived = ndx;  // save the number for use when printing
              ndx = 0;
              newData = true;
          else if (rb == startMarker) {
            recvInProgress = true;
      void showNewData() {
        if (newData == true) {
          //    Serial.print(" ... HEX Value.. ");
          for (byte n = 0; n < numReceived; n++) {
            Serial.print(receivedBytes[n], HEX);
            Serial.print(' ');
            if (receivedBytes[numReceived - 3] == 0x36 && receivedBytes[numReceived - 6] == 0x30) {
              unit = 0; // CM ARRI 60
            if (receivedBytes[numReceived - 3] == 0x37 && receivedBytes[numReceived - 6] == 0x30) {
              unit = 1; //FT ARRI 70
            if (unit == 0 && receivedBytes[numReceived - 6] == 0x31) {
              cm = receivedBytes[numReceived - 4] * 100 + receivedBytes[numReceived - 3] * 10 + receivedBytes[numReceived - 2];
            if (unit == 1 && receivedBytes[numReceived - 6] == 0x31) {
              ft = receivedBytes[numReceived - 5] * 10 + receivedBytes[numReceived - 4];
              inc = receivedBytes[numReceived - 3] * 10 + receivedBytes[numReceived - 2];
          Serial.println();
          Serial.print ("cm ");
          Serial.println (cm);
          Serial.print ("ft ");
          Serial.println (ft);
          Serial.print ("inc ");
          Serial.println (inc);
          newData = false;
      and this connections:
      machine----------------------------- RS422/TTL
      grd ------------------------------------ A ............. Y-----NC
      sgl ------------------------------------- B ............. Z----NC
      12V ----- +12v
      RS422/TTL ---------- ATOM
      TX ---------------------- RX
      RX -----------------------TX
      5V ---------------------- 5V
      GRD -------------------- GRD
      the newbie question is:
      can I use instead RS485 module based on SP485EEN-L ??
      tnks a lot
        cepics
        nobody?
        • m5stackM Offline
          The RS422 module you are using is not compatible with our RS485
            Johnny241 @m5stack
            @m5stack Hello!
            I would like to know to which bronchi pins A and B of the RS485 extension card are connected to the BUS, please.
            I can't get my M5 to communicate via RS485, however I soldered the small expansion card well.
            For my program I am using an ESP32 based Arduino library for the Modbus RTU
