UIFlow 1.5.1
@m5stack FW1.5.1 and UIFLow web 1.5.1
When trying to use the earth sensor (2 prong moisture sensor) firmware respond with Unit ADC and no function getRawValue.
@ajb2k3 OK, Thank you feedback. we will fix this bug as soon as possible
@plusulli for the time being, M5StickC don't have 1.5.1 FW. pls patient wait.
@m5stack AttributeError 'i2c' object has no attribute 'begin'
@ajb2k3 after what operation it return this error?
@m5stack Sorry should have said.
Trying to use the NCIR unit on port A -
@ajb2k3 ok......we will tracking this issues
@m5stack DCMotor and fan can not be controlled using PWM.
@m5stack FYI! I receive the error "DAC object has no attribute 'waveform' " in UIFlow when using the "dac0 waveform with..." block. Is this due to the last firmware? Thanks!
This post is deleted! -
@guors thank you feedback. we will fix this bug as soon as possible
