    UIFlow 1.5.1
    15 Posts 6 Posters 26.4k Views 2 Watching
      plusulli
      Where is the Demo for M5stickC ?
        I'm getting issues with using the earth unit on fw 1.5.1
        uiflow is calling adc instead of earth
          @m5stack FW1.5.1 and UIFLow web 1.5.1
          When trying to use the earth sensor (2 prong moisture sensor) firmware respond with Unit ADC and no function getRawValue.
          • m5stackM Offline
            m5stack @ajb2k3
            @ajb2k3 OK, Thank you feedback. we will fix this bug as soon as possible
            • m5stackM Offline
              m5stack @plusulli
              @plusulli for the time being, M5StickC don't have 1.5.1 FW. pls patient wait.
                ajb2k3 @m5stack
                @m5stack AttributeError 'i2c' object has no attribute 'begin'
                • m5stackM Offline
                  m5stack @ajb2k3
                  @ajb2k3 after what operation it return this error?
                    ajb2k3 @m5stack
                    @m5stack Sorry should have said.
                    Trying to use the NCIR unit on port A
                    • m5stackM Offline
                      m5stack @ajb2k3
                      @ajb2k3 ok......we will tracking this issues
                        @m5stack DCMotor and fan can not be controlled using PWM.
                        • G Offline
                          Guors
                          @m5stack FYI! I receive the error "DAC object has no attribute 'waveform' " in UIFlow when using the "dac0 waveform with..." block. Is this due to the last firmware? Thanks!
                            Pumpui @M5StickFreakler
                            • m5stackM Offline
                              m5stack @Guors
                              @guors thank you feedback. we will fix this bug as soon as possible
