    How to display picture
    5
    14.8k
    • P
      Powersoft
      How do I display a picture to the screen (M5Stack) from the SD-Card.
      I'm looking for an example.
      Thanks for any help.
      Cheers,
      Jan
      ajb2k3A K 2 Replies Last reply Reply Quote 0
        ajb2k3 @Powersoft
        @powersoft said in How to display picture:
        Cheers,
        Jan
        In what programming language?
        • P
          Powersoft
          I use the arduino envoirment.
          • lukasmaximusL
            Hey @Powersoft you can try this tutorial which @Dimi wrote some time ago on our forums, I believe the information should still be relevant http://forum.m5stack.com/topic/49/lesson-1-2-1-lcd-how-to-create-image-array/2
            • K
              kosternet @Powersoft
              @powersoft Maybe you find it interesting to know that there is a way of compiling a picture into your code so that you do not need an SD-card. This could make your solution more simple.
              To do:
              Download the UTFT-library from Rinky Dink Electronics (http://www.rinkydinkelectronics.com/library.php?id=51)
              Extract the download and use the Tools\Imageconverter565.exe to convert the image to a .c file (select AVR board)
              Open the .c file and change the line '#include <avr/pgmspace.h>' into '#include<pgmspace.h>'
              Insert the following lines in the file (the values should be the same as the image, 320x240 is max for M5Stack):
              const uint16_t imageWidth = 320;
              const uint16_t imageHeight = 240;
              Rename the .c file into .h (e.g. logo.c into logo.h) and place the file in the folder where the .ino-file for your project is
              In your Arduino-program add the following line in the top (or the other filename you have chosen)
              #include <M5Stack.h>
              #include "logo.h"
              In your Arduino-program add the following line in the 'setup'-function:
              M5.Lcd.setSwapBytes(true);
              In your Arduino-program add the following line in the place where you want to show the image:
              M5.Lcd.pushImage(0, 0, logoWidth, logoHeight, logo);
              I have included a link to a small demo-file on the following page:
              https://info.kosternet.nl/doku.php?id=publiek:m5stack
