    How to use two ENV units with PaHUB (UIFlow)
    Units
    5
    12
    22.9k
    • liemphL
      liemph
      I am new to UIFlow and need your guidance.
      I managed to get temperature, humidity, and pressure for a single ENV unit directly connected to my M5Stack Fire (Port A) using the UIFlow.
      Next, I have a PaHub and two ENV units. I connect the first and the second ENV unit to the port 0 and port 1 of the PaHub. I checked and tried to understand the Pa.HUB UIFlow example provided by the github (Pa.HUB.m5f). But still I could not understand how to proceed from the example to my goal, that is reading the two ENV units sequently. Please help!
      • liemphL
        liemph @liemph
        @liemph Sorry, I have solved my problem by watching Lucas video on YouTube.
        G 1 Reply Last reply Reply Quote 2
        • lukasmaximusL
          Glad the video helped ;)
          • G
            GrafoLabs @liemph
            @liemph Could you share the link to the video, please?
            • P
              Pepsi @GrafoLabs
              @grafolabs
              I think this is the video
              https://youtu.be/nMsCwqCE5c8
              It is clear in explaining the PaHUB with UIFlow
              • J
                jollawat
                Hi Guys
                I have some further question, what about M5Stick C + ENV HAT + PbHUB connect together?
                • liemphL
                  liemph @jollawat
                  @jollawat There is no problem. The pins used for the Hat (ENV HAT) and the ones used for the grove port (PbHUB) are different.
                  • J
                    jollawat @liemph
                    @liemph I tried connect and program by UIFlow it but there are some error after run on screen said “please remove ENV hat” when we add PbHUB into list.
                    liemphL 2 Replies Last reply Reply Quote 0
                    • liemphL
                      liemph @jollawat
                      @jollawat I did not get it. Please post also your configuration (the connection between Stick-C, Hat and Unit) and your code.
                      • liemphL
                        liemph @jollawat
                        @jollawat I do not have any ENV Hat, but I have a PIR Hat, and I tried to reconstruct your problem. I connected my PIR Hat and my PbHub (to Port A) of my Stick C. Then I connected my Light Unit to Port0 of my PbHub. Then I programmed using UiFlow to show the measurement results of both the PIR Hat and Light Unit. It worked well. Please see below, the code snapshot and list.
                        • liemphL
                          liemph
                          • liemphL
                            liemph
                            from m5stack import *
                            from m5ui import *
                            from uiflow import *
                            import hat
                            import unit
                            import hat
                            setScreenColor(0x111111)
                            pbhub0 = unit.get(unit.PBHUB, unit.PORTA)
                            hat_pir0 = hat.get(hat.PIR)
                            label0 = M5TextBox(13, 8, "PIR Hat", lcd.FONT_Default,0xFFFFFF, rotate=0)
                            label1 = M5TextBox(12, 63, "PbHUB", lcd.FONT_Default,0xFFFFFF, rotate=0)
                            label2 = M5TextBox(34, 34, "0", lcd.FONT_Default,0xFFFFFF, rotate=0)
                            label3 = M5TextBox(0, 83, "+Light Unit", lcd.FONT_Default,0xFFFFFF, rotate=0)
                            label4 = M5TextBox(26, 109, "0", lcd.FONT_Default,0xFFFFFF, rotate=0)
                            while True:
                              label2.setText(str(hat_pir0.state))
                              label4.setText(str(pbhub0.analogRead(0)))
                              wait(1)
                              wait_ms(2)
