    M5StickC + 18650C (HAT external battery) BAT pin
    M5 Stick/StickC
    4.5k
    • L
      liamharrison3
      Does anyone know where the BAT pin on the HAT connector goes? I see what I think is the internal battery voltage on it. So when I use the 18650C accessory the 18650 is connected in parallel with the internal battery? Is that correct?
      Thanks!
      • m5stackM
        m5stack @liamharrison3
        @liamharrison3 yes. the 18650 is connected in parallel with the M5StickC internal battery.
        • liemphL
          liemph @m5stack
          @m5stack This means that when the Stick is plug to the 18650C accessory, the 18650C accessory will not charge the internal battery?
