    Remote function on M5stickC
    M5 Stick/StickC
    6
    7
    12.3k
    • P
      Pictavius
      Hi
      is there a way to use the Remote fonction if UIFlow with StickC ?
      Blocks exists but i think screen is too small to see the QRcode.
      With size 80, i only have a white square, with size 82, part of QRcode is missing and my phone can't read it.
      I want to control the RoverC with my android phone.
      ajb2k3A R 2 Replies Last reply Reply Quote 1
        ajb2k3 @Pictavius
        @pictavius Yes its possible and I'm currently working on demo code as that is what I want to do.
        • R
          robalstona @Pictavius
          @pictavius you could see code displayed in qr on python tab and enter it manually in browser. I dont know what is rule to generate this code. It generate always the same or generate new every restart or something else?
          • P
            Pictavius @robalstona
            @robalstona
            As you can see on picture, Python code doesn't show the complete URL.
            I think full link is generated by server.
            I tried to upload the same program in my M5stack Fire, scanned the QRcode but it doesn't work with M5StickC after.
            • C
              clocey
              You can also use IFTTT and MQTT to communicate remotely
              • sysdl132S
                sysdl132
                I have same question on my m5stickC(old version).When I set it to 98,it display but it is difficult to scan it.But when I set it to 96 it only displays a white square.
                I think it's a big problem...
                For Atom:115200/230400/921600
                • lukasmaximusL
                  I was able to get a simple example of turning the stick LED on and off with a slider switch. You need to alter the coordinates and size of the qr in order to make it visible on the screen
                  Response is a little slow though, you may want to try IFTT or try to use http request and control from the browser or make an app with mit app inventor, I made a guide here a while ago, It's using arduino but I hope to do an updated version once I get an android phone. https://www.hackster.io/lukasmaximus89/m5stack-and-mit-app-inventor-47bd32
