    unable to flash after loading arduino tetris
    4.3k
    • D
      daavery
      gray m5 core
      Win7 - loaded tetris from arduino UI successfully. no trying to re-flash anything from arduino or m5burner it looks like the tetris load does not let the bootloader start. on any load attempt the system resets and then the tetris start screen appears. this repeats till the loader times out trying to connect. forcing a reset via the power button has no difference than the usb induced reset
      • D
        daavery
        from arduino serial monitor @ 115200 baud :
        rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
        configsip: 0, SPIWP:0xee
        mode:DIO, clock div:1
        load:0x3fff0018,len:4
        load:0x3fff001c,len:1216
        ho 0 tail 12 room 4
        load:0x40078000,len:9720
        ho 0 tail 12 room 4
        load:0x40080400,len:6352
        entry 0x400806b8
        M5Stack initializing...OK
        so the serial port seems to be working OK - but loader never connects
        • D
          daavery
          solved...sort of ... looks to be win7 problem - works fine on up to date win 10
          • m5stackM
            m5stack @daavery
            @daavery You can try more times on win7, maybe just baud rate issue or USB COM / cable issue.
