    New user needs direction
    8
    12.5k
    • L
      lanman1
      Hello, I have some LED strip visualizations projects i built in the Arduino IDE for Ardiono Nano boards that I recently ported over to ESP32. I bought a M5Stack to play with because i thought the graphical interface would be nice to control modes for the LED visualizations and sequences. So, can anyone point me in the right direction for creating a simple interface on the M5stack to integrate with my existing code? Or, would it make sent to try and port over to micropython/FlowUI? I would worry that the code wouldn't run fast enough on micropython for some of my visualizations.
      Any advice would be appreciated.
      liemphL ajb2k3A 2 Replies Last reply Reply Quote 0
      • liemphL
        liemph @lanman1
        @lanman1 said in New user needs direction:
        I am not a user of micropython/FlowUI and I do not want to make comment on that. However, I am using Arduino IDE for almost all of my projects. And when I ported my application from Ardunio Nano to ESP8266 or ES32 based M5Stack cores the natural option is to stick with the C++ of Arduino IDE. In your particular application, I think you have to modify the pin address, etc. Good luck.
          ajb2k3 @lanman1
          My book is still work in progress but I have got the RGB/neopixel functions in UIFlow finished.
          http://ajbryant.co.uk/UIFLOW/quickblockref.pdf
          • L
            lanman1
            Thanks all for the insight. I've looked at the flowUI and at making an interface in the Arduino IDE. The flowUI is really easy with great looking results but I really doubt I can get the frame rates where I'd like them in an interpreted language. I also think that writing an interface natively in the Arduino IDE would have a big impact on the frame rates as well. I may have to look at some co-processor arrangement where flowUI Handles the higher level functions and issues commands to a procesessor handling the IO.
            N ajb2k3A 2 Replies Last reply Reply Quote 0
            • N
              nsfilho @lanman1
              @lanman1 I suggest you to use PlatformIO IDE -- it is more sophisticated to develop and quickly when you rebuild (because have a nice cache system).
                ajb2k3 @lanman1
                You would be correct with processing as the arduino allows access to all 3 of the esp32's cores where as micropython code runs on one core, the interpreter runs on the other and the 3rd, the ULP core is inaccessible.
                • L
                  lanman1
                  PlatformIO, is that the one that uses Visual Studio? Do you know if its compiled or interpreted?
                  **Nevermind, I looked it up, I'm not sure what this gets me over the Arduino IDE that helps with making a menu/control interface.
                  • L
                    lanman1 @ajb2k3
                    @ajb2k3 said in New user needs direction:
                    Thanks again for your time and insight. I'm really impresses with the M5Stack, I have a lot of learning to do.
