    M5StickC usb driver and Catalina
    30 Posts 12 Posters 131.9k Views 2 Watching
    • m5stackM Online
      m5stack @sheepDog
      @sheepdog this problem from MAC OS FTDI driver , you can try to use WIN10 OS (like using a virtual machine) to upload program. also M5StickC Upload program don't need CP2104 Driver.
        sheepDog @m5stack
        @m5stack Thank you for your quick response. I am sure that Mac OS Catalina need a driver. A few days ago I installed Mac OS 10.15.2 form scratch and M5StickC needs the cp210x-driver (M5Stack needs the FTDI driver!).
        You can test it. If you connect a M5StickC you see at the directory /dev a file with this name "cu.usbserial-<number>". With connected M5Stack you see "cu.SLAB_USBtoUART" (<- This is the FTDI driver).
        My workaround is "Connect G0 pin to GND". That is not nice. Your solution to start a VM is even more complex because all need all my files there.
        Yes, I can program M5StickC, but I am looking for an easy way to program M5StickC with short turn around times and easy handling. Normally I used Atom editor with PlatformIO.
          tcruse
          @m5stack could you please advise on the best process for getting M5StickC to work and flash via esptool on Mac OS Catalina ?
          Also, advise on which driver is needed for M5StickC. Is it the FTDI driver or is it the CP210X driver ?
          • m5stackM Online
            m5stack @tcruse
            @tcruse first , on some Mac PC, M5StickC cannot upload program properly.
            the solution: When programming, short the G0 to GND using the DuPont line.
            and , all most PC don't need driver with M5StickC. But some old PC System need install FTDI driver.
            FTDI driver is for M5StickC, CP2104 driver is for M5Stack Core ( like Fire BASIC M5GO)
              sheepDog @m5stack
              @m5stack Yes, I swapped the drivers. You can check it at Apple menu, systemreport and USB.
              1. If I connected a M5Stack I saw:
              2. If I connected a M5StickC I saw:
              You can check the loaded drivers and their versions in terminal with "sudo kextstat".
              I noticed that sometimes M5Stack didn't not work without "short the G0 to GND". I think that is a timing-problem at Catalina and esptool.py. It is not a problem of M5Stack- or M5StickC-Software.
                sheepDog
                I formulated an Issue at Github: Link to Issue
                Supplement on January 18, 2020: You need an Espressif account to see the issue.
                • m5stackM Online
                  m5stack @sheepDog
                  D S 2 Replies Last reply Reply Quote 0
                    diogovaraujo @m5stack
                    @m5stack Cant click that link.
                      sheepDog @m5stack
                      @m5stack
                      I got this error if I click your link: "Access denied. You do not have permission to access this page."
                      Thank you for updating your software.
                      • world101W Offline
                        world101
                        The link worked for me once a few hours ago, but now it’s not.
                        • N Offline
                          nsfilho @o.copleston
                          @o-copleston This solution is running perfectly! Thank you!
                          • m5stackM Online
                            m5stack @diogovaraujo
                            It may make your firmware lose and make it unusable, so if you are willing to take this risk, you can chat with me in private and I will give you a link to download the tool @sheepDog @world101
                              sheepDog @m5stack
                              @m5stack Hello, are there any news about a solution for Catalina and M5StickC?
                              • N Offline
                                nsfilho @sheepDog
                                @m5stack if you can, please give us the link for a new driver to solve that problem....
                                • m5stackM Online
                                  m5stack @nsfilho
                                  @nsfilho @sheepDog Please read the information carefully before using the tool
                                  link:
                                  http://community.m5stack.com/topic/1591/m5stickc-and-atom-on-macos-platform-can-t-upload-programs-solustion
                                  • N Offline
                                    nsfilho @m5stack
                                    @m5stack Thank you! The solution 2 (as describe in link) is fully functional.
