    M5stick C compiling issue
    M5 Stick/StickC
    4.2k
    • E
      eternalgrace94
      Usually when press run, the code will upload and the device will run the program accordingly, but as of recent, I have to reboot the device so it will run the program
      Anyone knows a solution to this, or is this device damaged?
      • E
        eternalgrace94
        Now when i plug in the device, its says device cannot be recognised
        • m5stackM
          what PC system are you used ? are you used UIFlow Desktop IDE ? could you provide more information about this problem?
            ajb2k3 @eternalgrace94
            @eternalgrace94 said in M5stick C compiling issue:
            I get this from time to time especially when im updating code several times in quick succession, and yeh, I just do a full restart.
            If you have issues connecting to the UIFlow Website it may be due to server load as there are alot of people trying to access the server.
