    M5Stack Fire and M5 Piano?
    Modules
    7.3k
      mmroos
      So I ordered a M5stack Fire and a M5 Piano. Now I found out that the Piano's 15 pin connector cannot fit anywhere on my M5Stack. Is there a way to convert grove to those 15 pins or is there another solution? Preferably one where I do not have to sacrifice my 600ah battery.
      • ChrisWRC
        ChrisWR
        get a proto and build the 15 pins female port in it..
        Proto stack
          ajb2k3 @mmroos
          @mmroos said in M5Stack Fire and M5 Piano?:
          The Keyboard is designed for the I/O Base plate
          https://m5stack.com/collections/m5-base/products/battery-bottom-150mah?ref=pfpqkvphmgr
          alt text
          Here is the know information on the keyboard.link text
          The pins can be found on the internal 2X15 pin internal bus connection.
