đŸ€–Have you ever tried Chat.M5Stack.com before asking??😎
    Members Introductions aka The Icebreaker discussion.
    73 Posts 26 Posters 356.9k Views 5 Watching
      Be very careful with the units. They have colour coded connectors and only work with matching ports.
      How do you know that there is no 5v on the other ports?
        Red_Ant
        Hi ajb2k3,
        I measured it with a multimeter ... no I didn't put the probes into the connector ... first I applied the original grove cable to the M5 and then extended it by breadboard cables, where it was easy and safe to connect the multimeter.
        And so I did for all three ports ... only on port A 5V could be seen
          ajb2k3 @Red_Ant
          @red_ant Is the base fitted securely and squarely to the face plate?
            Red_Ant
            @ajb2k3 ,
            I think so ... the screws seems to be tightened
              ajb2k3 @Red_Ant
              @red_ant
              Do the leds on the side of the base work?
                Red_Ant @ajb2k3
                @ajb2k3 ,
                shall we continue this discussion somewhere else ? Move it to another place in the forum ?
                Regarding the question ... I can't see any LEDs
                  JRelland
                  I am José, from France.
                  Congratulations for M5 Stack and for the all the community projects.
                  Interesting in M5 Stack starter kit.
                  I imagine, only online.
                  Have a great time with M5 Stack
                  [fr] Bonjour,
                  Je suis José de Troyes, France.
                  Félicitations pour M5 Stack et pour les projets de la communauté :).
                  Je suis intéressé par un kit de démarrage M5 Stack
                  J'imagine qu'on le trouve uniquement en ligne.
                  Bonnes fĂȘtes de fin d'annĂ©e :)
                  José
                  Amicalement / Best Regards
                  José from France
                    MCHack @LastCaress
                    @lastcaress Hey Lukas, I have just implemented a M5Stack-C Project for Orientation during sleep that works fine. Is there a place where we can share our programs? Did not find that. yet.
                      ajb2k3 @MCHack
                      @mchack there is the project forum designed just for that!
                        MCHack @ajb2k3
                        @ajb2k3 Jup, I found it and created my project on https://www.hackster.io :)
                          ajb2k3 @MCHack
                          @mchack said in Members Introductions aka The Icebreaker discussion.:
                          there is also a project section of the forum just for this!
                          http://community.m5stack.com/category/2/projects
                          • MashBalM Offline
                            MashBal
                            I am My name is Mehwish and I am also new here. hope we will spend a good time here.
                            • AsmodevA Offline
                              Asmodev
                              Hiya, My name is Matthew, I'm in love with M5Stack products, they're not too publicly discerning, and allows me to move my projects around with ease! I love AI and I have 3x m5 sticks, each one has its own uniqueness and I love trying to make things work with them, like my tello drone.
                              I'm still learning about unitv2 but when they update the firmware for the access point i'll be able to have a lot more fun! - See you all on the stackside!
                              • DR_Froggy_rDD Offline
                                DR_Froggy_rD
                                Hi Adam,
                                I am french living in Zurich and interested in dIY stuff I own 2 3d printer and having 2 that are dust trap (one is broken ( a crap m3d printer micro...not repaire-able ) but ok... I design more than 70 opensource design to be 3d printed.... I have assembled a nerdy gurdy for which I designed additionnal thingiverse models... I am active on the prusa community forum... I wanted to programm a xyz accelerometer export to enable easy instant shaping...
                                  What's your thingiverse?
                                  I'm other as CPT_James_Purcell
                                    DR_Froggy_rD
                                    I just search for you on thingiverse not able to find you
                                    look for "micro handle repair with storm Mando helmet low poly"
                                    did you made a design? what tittle?
                                      DR_Froggy_rD
                                      For me I am pissed off by obsolescence... and therefore I gather reusable trash from the street I f I see a possibility to do ...
                                      I like repair stuff. and understand thing...
                                        https://www.thingiverse.com/cptjamespurcell/designs
                                        Sorry got lock out again
                                          DR_Froggy_rD
                                          I found you and let you a comment on your atom choacker building block
                                            Davies
                                            Hello everyone, I work in a stepper motor factory and like singing and traveling in my spare time.
                                            [url=https://www.skysmotor.co.uk/category-6-b0-Nema-17-Stepper-Motor.html][color=#666666]nema 17 stepper motor[/color][/url]
