    SH200I test strange results
    M5 Stick/StickC
    11.6k
    • V
      vvs551
      Why there are always gyro results the same in any static position of m5stick?
        salty_good @vvs551
        @vvs551 Hi, thank you for your question.
        It is normal.
        The gyro sensor detects angular velocity. so if M5StickC is not rotating, gyro value also not change.
        V 1 Reply Last reply Reply Quote 0
        • V
          vvs551 @salty_good
          @salty_good why such values? What does it mean?
            salty_good @vvs551
            @vvs551 sorry, I didn't understand your mean.
            You mean M5StickC need to be (x, y, z) = (0, 0, 0) in any static position?
            Because it's no calibration in the test code now...
            • V
              vvs551 @salty_good
              @salty_good Thank you! I understand
              I have not met before the calibration requirements for i2c digital sensors)
              Sorry
                salty_good
                @vvs551 so sorry...
                We will provide calibrated version code in the future!!
                V hagueH 2 Replies Last reply Reply Quote 0
                • V
                  vvs551 @salty_good
                  @salty_good Could you propose any idea how to calibrate data and get real time angle monitoring sketch?
                  Because there is a terrible fluctuations from the meaning value in the time.
                  I could not get something near zero in static position if I do accumulative addition like here:
                  gyroX += ((float)gX * M5.IMU.gRes - gyroX0);
                  Where gX - int16_t current gyro value, gyroX0 - float calibration value with gRes, and gyroX - float accumulative angle value
                  • hagueH
                    hague @salty_good
                    @salty_good Is there a calibration yet? Any update?
