    Any updates on the mpu6886?
    Scheduled Pinned Locked Moved M5Stick V
    8 Posts 6 Posters 21.4k Views 1 Watching
    • X Offline
      Xeon
      Can this be used somehow?
      i haven't found any examples.
      The war of 1 and 0 draws ever closer.
      everyday i work to become a cyborg.
        staberas @Xeon
        @xeon sorry for resurrecting old post, i had the same problem, i currently close getting data from the IMU
          staberas
          done, used party code from anoken who sourced it from the arduino version , i clean up and updated it
          import image
          import lcd
          import sensor
          import sys
          import time
          import utime
          from board import board_info
          import KPU as kpu
          from Maix import GPIO
          from fpioa_manager import *
          from pmu import axp192
          from machine import I2C
          #pmu = axp192() - breaks IMU data -
          #pmu.enablePMICSleepMode(True) - breaks IMU data -
          i2c = I2C(I2C.I2C0, freq=400000, scl=28, sda=29)
          #devices = i2c.scan()
          lcd.init()
          # IMU6866 define
          MPU6886_ADDRESS=0x68
          MPU6886_WHOAMI=0x75
          MPU6886_ACCEL_INTEL_CTRL=0x69
          MPU6886_SMPLRT_DIV=0x19
          MPU6886_INT_PIN_CFG=0x37
          MPU6886_INT_ENABLE=0x38
          MPU6886_ACCEL_XOUT_H=0x3B
          MPU6886_TEMP_OUT_H=0x41
          MPU6886_GYRO_XOUT_H=0x43
          MPU6886_USER_CTRL= 0x6A
          MPU6886_PWR_MGMT_1=0x6B
          MPU6886_PWR_MGMT_2=0x6C
          MPU6886_CONFIG=0x1A
          MPU6886_GYRO_CONFIG=0x1B
          MPU6886_ACCEL_CONFIG=0x1C
          MPU6886_ACCEL_CONFIG2=0x1D
          MPU6886_FIFO_EN=0x23
          # IMU6866 Initialize
          def write_i2c(address, value):
          	i2c.writeto_mem(MPU6886_ADDRESS, address, bytearray([value]))
          	time.sleep_ms(10)
          write_i2c(MPU6886_PWR_MGMT_1, 0x00)
          write_i2c(MPU6886_PWR_MGMT_1, 0x01<<7)
          write_i2c(MPU6886_PWR_MGMT_1,0x01<<0)
          write_i2c(MPU6886_ACCEL_CONFIG,0x10)
          write_i2c(MPU6886_GYRO_CONFIG,0x18)
          write_i2c(MPU6886_CONFIG,0x01)
          write_i2c(MPU6886_SMPLRT_DIV,0x05)
          write_i2c(MPU6886_INT_ENABLE,0x00)
          write_i2c(MPU6886_ACCEL_CONFIG2,0x00)
          write_i2c(MPU6886_USER_CTRL,0x00)
          write_i2c(MPU6886_FIFO_EN,0x00)
          write_i2c(MPU6886_INT_PIN_CFG,0x22)
          write_i2c(MPU6886_INT_ENABLE,0x01)
          # Read IMU6866 and Scaling
          def read_imu():
          	aRes=255/4096/2
          	gRes = 2000.0/32768.0
          	offset=128
          	accel = i2c.readfrom_mem(MPU6886_ADDRESS, MPU6886_ACCEL_XOUT_H, 6)
          	accel_x = (accel[0]<<8|accel[1])
          	accel_y = (accel[2]<<8|accel[3])
          	accel_z = (accel[4]<<8|accel[5])
          	if accel_x>32768:
          		accel_x=accel_x-65536
          	if accel_y>32768:
          		accel_y=accel_y-65536
          	if accel_z>32768:
          		accel_z=accel_z-65536
          	ax=int(accel_x*aRes+offset)
          	if ax<0: ax=0
          	if ax>255: ax=255
          	ay=int(accel_y*aRes+offset)
          	if ay<0: ay=0
          	if ay>255: ay=255
          	az=int(accel_z*aRes+offset)
          	if az<0: az=0
          	if az>255: az=255
          	accel_array = [ax,ay,az]
          	gyro = i2c.readfrom_mem(MPU6886_ADDRESS, MPU6886_GYRO_XOUT_H, 6)
          	gyro_x = (gyro[0]<<8|gyro[1])
          	gyro_y = (gyro[2]<<8|gyro[3])
          	gyro_z = (gyro[4]<<8|gyro[5])
          	if gyro_x>32768:
          		gyro_x=gyro_x-65536
          	if gyro_y>32768:
          		gyro_y=gyro_y-65536
          	if gyro_z>32768:
          		gyro_z=gyro_z-65536
          	gx=int(gyro_x*gRes+offset)
          	if gx<0: gx=0
          	if gx>255: gx=255
          	gy=int(gyro_y*gRes+offset)
          	if gy<0: gy=0
          	if gy>255: gy=255
          	gz=int(gyro_x*gRes+offset)
          	if gz<0: gz=0
          	if gz>255: gz=255
          	gyro_array = [gx,gy,gz]
          	return accel_array, gyro_array
          lcd.rotation(2)
          task = kpu.load("/sd/7118109ae3ea570e_mbnet10_quant.kmodel")#change model
          labels=["seadog","Borbya","mermaid","Villo"] #change names.
          sensor.reset()
          sensor.set_pixformat(sensor.RGB565)
          sensor.set_framesize(sensor.QVGA)
          sensor.set_windowing((224, 224))
          sensor.run(1)
          lcd.clear()
          while(True):
          	accel_array,gyro_array = read_imu()
          	img = sensor.snapshot()
          	fmap = kpu.forward(task,img)
          	plist=fmap[:]
          	pmax=max(plist)
          	#lcd.draw_string(40, 20, str(accel_array))
          	#lcd.draw_string(10, 40, str(gyro_array))
          	max_index=plist.index(pmax)
          	if pmax > 0.95:
          		#lcd.draw_string(40, 60, "Accu:%.2f Type:%s"%(pmax, labels[max_index].strip()))  #20-59,130-136,55-30 [side view] 100-130,130-136,9-20 [top view]
                  #the values are from 0 to 255
          		if accel_array[0] > 20 and accel_array[0] < 59 and accel_array[1] > 130 and accel_array[1] < 136 and accel_array[2] > 30 and accel_array[2] < 55:
          			img.draw_image(image.Image("/sd/view2.jpg"), 50, 50,x_scale=0.5,y_scale=0.5,mask=image.Image("/sd/view2t.jpg"))
          		if accel_array[0] > 60  and accel_array[0] < 130 and accel_array[1] > 130  and accel_array[1] < 137 and accel_array[2] > 8 and accel_array[2] < 20:
          			img.draw_image(image.Image("/sd/view1.jpg"), 50, 50,x_scale=0.5,y_scale=0.5,mask=image.Image("/sd/view1t.jpg"))
          	a = lcd.display(img)
          a = kpu.deinit(task)
          sys.exit()
          B A P 3 Replies Last reply Reply Quote 1
          • B Offline
            Bryam @staberas
            @staberas Como lo instalas no me reconoce si creo un ide en arduino
              staberas @Bryam
              @bryam
              The code above is for the maixpy (micropython) not arduino
                Alisson Brito @staberas
                @staberas I'm trying to run your example on the M5Stick V but I have a error message when trying to write_i2c for the first time. The error is: "OSError: [Errno 5] EIO". Do you know what does it means?
                • m5stackM Offline
                  you could find the MPU6886 example in this page:
                  https://docs.m5stack.com/#/en/related_documents/M5StickV-Maixpy
                    purpledread @staberas
                    @staberas
                    This code was very helpful. Thanks!
                    I tried adding temperature as well:
                    tmp = i2c.readfrom_mem(MPU6886_ADDRESS, MPU6886_TEMP_OUT_H, 2)
                    temp = (tmp[0]<<8|tmp[1])
                    temp = (float(temp) / 326.8) + 25.0;
                    I'm getting temps of 40.5C (105F). Am I doing something wrong or is this temperature the CPU temp?
                    Thanks,
                    /Chris
