    Heart rate unit with M5Stick
    Modules
    7.1k
    • R
      RuslanCC
      Hello! My heart rate unit is working with m5stack, but it dosen't work with m5stick. Code is the same. When I turn on m5stick sensor flashes for about 0.5 second and then remain dim, so serial monitor return 0 for forever. What is the problem? Thanks.
      • lukasmaximusL
        Hi @RuslanCC could you tell us which language your programming in and perhaps share your code with us
        • R
          RuslanCC
          I use code from here:
          https://m5stack.com/products/mini-heart-unit
          Arduino IDE
          • R
            RuslanCC
            Why is this marked as solved if it isn't working?
              ajb2k3 @RuslanCC
              @ruslancc Unknown but I have fixed that now.
              It could be that the M5Stick can not provide enough power for the heart rate monitor.
              You could try connecting one of these
              https://m5stack.com/collections/m5-accessory/products/grove-t-connector-5pcs-a-pack
              alt text
              between the Stick and the heart rate monitor and use the other connection to provide an additional power supply for the monitor.
