    StickC - Serial Problems
    M5 Stick/StickC
    16.2k
    • C
      cmisztur
      Ordered StickC from Amazon. Label on plastic box: @1043907@07-02.
      Can't get a COM port on Windows 10. Most of the time 'Unknown USB Device (Device Descriptor Request Failed)', so I can't even install the correct driver. Works sometimes on OSX. Used M5Burner to flash 1.4.0-b, then 1.3.2 after 10 tries. I want to reflash with 1.3.2. But now all I get is: 'Could not configure port (6, Device Not Configured).
      Any ideas?
      Chris
      • C
        cmisztur
        Tried again on PC, came up as 'USB Serial Device'. Installed 'FT4222 Mode 3 Device' driver 2.12.0.0. Got a COM port. Kind of works. Mostly it keeps disconnecting/reconnecting.
        I can no longer see the device on OSX 10.14.6. Nothing pops up in security about CP driver.
        • C
          cmisztur
          Flipped USB-C cable around, now it is showing up in OSX.
          Going to stick ... ha... with Arduino IDE for now.
            ajb2k3 @cmisztur
            @cmisztur said in StickC - Serial Problems:
            I'm assuming you are you the lead that came with the Stick?
            If the issue pops up again try a new high quality lead as this is a known issue with cheep leads.
            Also mark the usbc end so that you know which way around it should be.
            • C
              cmisztur
              Used the cable that came with it, marked M5. I don't know that is the issue. Before I really had a hard time I modified boot.py and noticed I was getting a GURU error, so ESP was stuck in a never ending reboot.
              • C
                cmisztur
                Same story this morning. Last night flashed the Arduino FactoryTest. This morning trying to get this thing connected on Windows, which is where I flashed it last night.
                • C
                  cmisztur
                  Got another one from Amazon and this one works just fine. Chalking it up to busted during shipping :).
                    ajb2k3 @cmisztur
                    Stick or lead?
                    also don't edit boot.py
                    • C
                      cmisztur @ajb2k3
                      @ajb2k3 Tried a different cable, so I'm assuming stick. Why not edit boot.py. It's micropython, as long as I call the M5 libs during the process, everything should work as intended.
