    M5stickC and VL53L1X sensor GROVE port
    M5 Stick/StickC
    9.0k
    • C
      cepics
      Hi, is it possible to connect VL53L1X sensor to M5StickC on GROVE port?
      I dont know how to set sda and scl pins of the GROVE... maybe with Wire1 ??
      I'm using arduino IDE
      this code doesn't work..
      #include <M5StickC.h>
      #include <Wire.h>
      #include <VL53L1X.h>
      VL53L1X sensor;
      float accX = 0;
      float accY = 0;
      float accZ = 0;
      int cm;
      int feet;
      int inches;
      int INCHES;
      bool unit = 0;
      #define TFT_GREY 0x5AEB // New colour
        Wire.begin();
        Wire.begin(32, 33); // (SDA, SCL) grove stickC
        Wire.setClock(400000); // use 400 kHz I2C
        M5.Lcd.setRotation(3);
        M5.MPU6886.Init();
        sensor.setDistanceMode(VL53L1X::Long);
        sensor.setMeasurementTimingBudget(50000);
        sensor.startContinuous(50);
        M5.MPU6886.getAccelData(&accX, &accY, &accZ);
        if (accX < 0) {
        } else {
          M5.Lcd.setRotation(1);
          cm = (sensor.read() / 10); //CM
          inches = cm / 2, 54;
          feet = inches / 12;
          INCHES = inches % 12; //es x = 7% 5; // X ora contiene 2
        M5.Lcd.fillScreen(TFT_GREY);
        M5.Lcd.setCursor(10, 16);
        M5.Lcd.setTextColor(TFT_YELLOW);
        M5.Lcd.setTextFont(7);
        //M5.Lcd.println(12.10);
        M5.Lcd.println(cm);
        delay(100);
      tnks a lot
      • C
        cepics
        nobody?
          Have you tried this code sample yet?
          https://github.com/m5stack/M5-ProductExampleCodes/blob/master/Unit/TOF/Arduino/TOF_VL53L0X/TOF_VL53L0X.ino
          BTW there is a new TOF Hat for the stick C
          https://m5stack.com/collections/all/products/m5stickc-tof-hatvl53l0x
          • W
            wikistik
            @cepics said in M5stickC and VL53L1X sensor GROVE port:
            VL53L1X
            I tried the VL53L0X unit on the grove port of the stick several times and could not get it to work. I know that really doesn't really help you but at least your are not alone in this quest :)
