Persistent storage management on the M5Stick-C
I would like to know if it is possible, and if yes how, could I write from micropython a file with telemetry data.
Just as a precision if it matters, I am using VS code with the M5 plugin to run the python code on the M5Stick-C.I've tried the following as a test with no success.
f = open("log.txt", "w+") f.write("Writing content from MicroPython") f.close()
The file is created (but disappear after soft reboot) and stay empty.
My understanding is that the "flash/" folder is mounted on a FAT filesystem.
So I would assume that it is possible to write on the micro-controller memory in this space.Thank you by advance for your support.
Regards,
Antowan
