    Screen orientation on UI flow
    M5 Stick/StickC
    6.0k
    • antowanA
      antowan
      I would like to know if there is any way to change the screen rotation on the UI flow designer for the m5stick-c.
      The function "set screen rotate mode" seems to work but it is not reflected on the UI for the design part.
      Therefore this image is not rotated properly. Does that mean it has to be done manually ? (ie rotating the jpg before importing it)
      Thanks by advance for your feedback.
      Regards,
      Antowan
        ajb2k3 @antowan
        @antowan It is better to have the image in the correct orientation before importing to the M5Stick or stick.
        The Block for screen rotation has only just been added to UIFlow.
        antowanA 1 Reply Last reply Reply Quote 0
        • antowanA
          antowan @ajb2k3
          @ajb2k3 Thank you for your quick answer, I have imported the JPG pre-rotated for the moment and it works fine.
