    M5StickC built in LED
    M5 Stick/StickC
    5
    6
    15.3k
    • W
      wikistik
      Any insight on how the red led on pin 10 of the M5StickC is wired up?
      I noticed that, using the Arduino IDE
      pinMode(10, OUTPUT);
      turns the LED on and subsequently
      digitalWrite(10, HIGH);
      turns it OFF, while
      digitalWrite(10, LOW);
      turns it ON again
      • K
        Kyklist
        Its common to wire a LED to a GPIO (pin) as Active "Low".
        One pin of the LED gets wired to +V and the other pin goes to the GPIO.
        At some point there is most likely a resister to limit the current.
        Apparently its easier (less heat?) for the GPIO (pin) to source power by pulling the circut "low".
        • W
          wsanders @Kyklist
          (I'll go ahead and bump this. So sue me.)
          Bear in mind that when you initialize the pin with:
          pinMode(M5_LED, OUTPUT);
          digitalWrite (M5_LED, HIGH); // turn off the LED
          The LED will blink briefly. I don't know of a workaround. I also know virtually nothing about ESP pin frobbing.
            It’s a oddity that some pins on the esp32 variant often work backwards
              Hello @wsanders
              I don't see the brief blink myself, but have you tried to swap the two statements?
              • W
                wsanders @felmue
                Thanks! That workaround works.
                You only see the brief flash when applying power or when the IDE uploads the code and hard resets via RTS.
                If you do this:
                #include <M5StickCPlus.h>
                digitalWrite (M5_LED, HIGH); // off
                delay(10);
                ESP.restart();
                the LED does not flash repeatedly.
