šŸ¤–Have you ever tried Chat.M5Stack.com before asking??šŸ˜Ž
    Where can I find an example of retrieving data from BMM150 + SH200Q
    M5Stack Fire
    10
    18.5k
    • Y
      Yova
      I try to use any library but did not succeed
      • Y
        Yova
        Try for BMM150 : https://github.com/BoschSensortec/BMM150-Sensor-API
        SH200Q : https://github.com/elegooTech/SH200Q/tree/master/SH200资ꖙ
        • F
          Florian5442
          I can't find working examples neither. It would be nice if there was included examples in the M5Stack Arduino library. If someone can help it would be great. Thanks !
            mpetra
            Hello @Yova,
            there is a standard library for SH200Q available for the M5Stick. Since I have a M5Stack Fire core, I ported this library in order to work for this device. You can find it at the address: https://github.com/scavallero/SH200Q.
            I will put there an example as soon as possible.
            • R
              rosolino.net
              Prova questa libreria
              https://github.com/Seeed-Studio/Grove_3_Axis_Compass_V2.0_BMM150
              poi modifica BMM150_I2C_Address 0x13 con 0x10 nel file bmm150_defs.h
              in questo modo dovresti poter accedere al BMM150.
              Purtroppo M5STACK ha i magneti sul fondo
              Try this library
              then modify BMM150_I2C_Address 0x13 with 0x10 in the file bmm150_defs.h
              this way you should be able to access the BMM150.
              Unfortunately M5STACK has magnets on the bottom
              • R
                rosolino.net
                In ogni caso potrai calibrare la bussola con lo sketc figure8_calibration.ino ruotando in varie direzioni M5STACK
                In any case, you can calibrate the compass with the sketc figure8_calibration.ino by rotating in various directions M5STACK
                • R
                  rosolino.net
                  https://appelsiini.net/2018/calibrate-magnetometer/
                  • R
                    rosolino.net
                    https://youtu.be/p8g6cfSeYos
                    • R
                      rosolino.net
                      https://youtu.be/2ngq1xJJs40
                      • R
                        rosolino.net
                        https://rosolinoblog.wordpress.com/2020/01/29/adesso-gioco-con-questo/
