<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Where can I find an example of retrieving data from BMM150 + SH200Q]]></title><description><![CDATA[<p dir="auto">I try to use any library but did not succeed</p>
]]></description><link>https://community.m5stack.com/topic/1177/where-can-i-find-an-example-of-retrieving-data-from-bmm150-sh200q</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 08:01:39 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1177.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 02 Aug 2019 13:44:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Where can I find an example of retrieving data from BMM150 + SH200Q on Wed, 29 Jan 2020 08:58:46 GMT]]></title><description><![CDATA[<p dir="auto"><a href="https://rosolinoblog.wordpress.com/2020/01/29/adesso-gioco-con-questo/" target="_blank" rel="noopener noreferrer nofollow ugc">https://rosolinoblog.wordpress.com/2020/01/29/adesso-gioco-con-questo/</a></p>
]]></description><link>https://community.m5stack.com/post/7237</link><guid isPermaLink="true">https://community.m5stack.com/post/7237</guid><dc:creator><![CDATA[rosolino.net]]></dc:creator><pubDate>Wed, 29 Jan 2020 08:58:46 GMT</pubDate></item><item><title><![CDATA[Reply to Where can I find an example of retrieving data from BMM150 + SH200Q on Wed, 29 Jan 2020 08:58:03 GMT]]></title><description><![CDATA[<p dir="auto"><a href="https://youtu.be/2ngq1xJJs40" target="_blank" rel="noopener noreferrer nofollow ugc">https://youtu.be/2ngq1xJJs40</a></p>
]]></description><link>https://community.m5stack.com/post/7236</link><guid isPermaLink="true">https://community.m5stack.com/post/7236</guid><dc:creator><![CDATA[rosolino.net]]></dc:creator><pubDate>Wed, 29 Jan 2020 08:58:03 GMT</pubDate></item><item><title><![CDATA[Reply to Where can I find an example of retrieving data from BMM150 + SH200Q on Wed, 29 Jan 2020 08:56:42 GMT]]></title><description><![CDATA[<p dir="auto"><a href="https://youtu.be/p8g6cfSeYos" target="_blank" rel="noopener noreferrer nofollow ugc">https://youtu.be/p8g6cfSeYos</a></p>
]]></description><link>https://community.m5stack.com/post/7235</link><guid isPermaLink="true">https://community.m5stack.com/post/7235</guid><dc:creator><![CDATA[rosolino.net]]></dc:creator><pubDate>Wed, 29 Jan 2020 08:56:42 GMT</pubDate></item><item><title><![CDATA[Reply to Where can I find an example of retrieving data from BMM150 + SH200Q on Wed, 29 Jan 2020 07:16:09 GMT]]></title><description><![CDATA[<p dir="auto"><a href="https://appelsiini.net/2018/calibrate-magnetometer/" target="_blank" rel="noopener noreferrer nofollow ugc">https://appelsiini.net/2018/calibrate-magnetometer/</a></p>
]]></description><link>https://community.m5stack.com/post/7233</link><guid isPermaLink="true">https://community.m5stack.com/post/7233</guid><dc:creator><![CDATA[rosolino.net]]></dc:creator><pubDate>Wed, 29 Jan 2020 07:16:09 GMT</pubDate></item><item><title><![CDATA[Reply to Where can I find an example of retrieving data from BMM150 + SH200Q on Wed, 29 Jan 2020 00:38:22 GMT]]></title><description><![CDATA[<p dir="auto">In ogni caso potrai calibrare la bussola con lo sketc figure8_calibration.ino ruotando in varie direzioni M5STACK</p>
<p dir="auto">In any case, you can calibrate the compass with the sketc figure8_calibration.ino by rotating in various directions M5STACK</p>
]]></description><link>https://community.m5stack.com/post/7231</link><guid isPermaLink="true">https://community.m5stack.com/post/7231</guid><dc:creator><![CDATA[rosolino.net]]></dc:creator><pubDate>Wed, 29 Jan 2020 00:38:22 GMT</pubDate></item><item><title><![CDATA[Reply to Where can I find an example of retrieving data from BMM150 + SH200Q on Wed, 29 Jan 2020 00:30:07 GMT]]></title><description><![CDATA[<p dir="auto">Prova questa libreria<br />
<a href="https://github.com/Seeed-Studio/Grove_3_Axis_Compass_V2.0_BMM150" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Seeed-Studio/Grove_3_Axis_Compass_V2.0_BMM150</a></p>
<p dir="auto">poi modifica BMM150_I2C_Address 0x13 con 0x10 nel file bmm150_defs.h</p>
<p dir="auto">in questo modo dovresti poter accedere al BMM150.<br />
Purtroppo M5STACK ha i magneti sul fondo</p>
<p dir="auto">Try this library<br />
<p dir="auto">then modify BMM150_I2C_Address 0x13 with 0x10 in the file bmm150_defs.h</p>
<p dir="auto">this way you should be able to access the BMM150.<br />
Unfortunately M5STACK has magnets on the bottom</p>
]]></description><link>https://community.m5stack.com/post/7230</link><guid isPermaLink="true">https://community.m5stack.com/post/7230</guid><dc:creator><![CDATA[rosolino.net]]></dc:creator><pubDate>Wed, 29 Jan 2020 00:30:07 GMT</pubDate></item><item><title><![CDATA[Reply to Where can I find an example of retrieving data from BMM150 + SH200Q on Thu, 29 Aug 2019 07:04:54 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/yova" aria-label="Profile: Yova">@<bdi>Yova</bdi></a>,<br />
there is a standard library for SH200Q available for the M5Stick. Since I have a M5Stack Fire core, I ported this library in order to work for this device. You can find it at the address: <a href="https://github.com/scavallero/SH200Q" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/scavallero/SH200Q</a>.<br />
I will put there an example as soon as possible.</p>
]]></description><link>https://community.m5stack.com/post/5363</link><guid isPermaLink="true">https://community.m5stack.com/post/5363</guid><dc:creator><![CDATA[mpetra]]></dc:creator><pubDate>Thu, 29 Aug 2019 07:04:54 GMT</pubDate></item><item><title><![CDATA[Reply to Where can I find an example of retrieving data from BMM150 + SH200Q on Wed, 28 Aug 2019 15:45:33 GMT]]></title><description><![CDATA[<p dir="auto">I can't find working examples neither. It would be nice if there was included examples in the M5Stack Arduino library. If someone can help it would be great. Thanks !</p>
]]></description><link>https://community.m5stack.com/post/5352</link><guid isPermaLink="true">https://community.m5stack.com/post/5352</guid><dc:creator><![CDATA[Florian5442]]></dc:creator><pubDate>Wed, 28 Aug 2019 15:45:33 GMT</pubDate></item><item><title><![CDATA[Reply to Where can I find an example of retrieving data from BMM150 + SH200Q on Mon, 05 Aug 2019 11:04:48 GMT]]></title><description><![CDATA[<p dir="auto">Try for BMM150 : <a href="https://github.com/BoschSensortec/BMM150-Sensor-API" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/BoschSensortec/BMM150-Sensor-API</a><br />
SH200Q : <a href="https://github.com/elegooTech/SH200Q/tree/master/SH200%E8%B5%84%E6%96%99" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/elegooTech/SH200Q/tree/master/SH200资料</a></p>
]]></description><link>https://community.m5stack.com/post/5018</link><guid isPermaLink="true">https://community.m5stack.com/post/5018</guid><dc:creator><![CDATA[Yova]]></dc:creator><pubDate>Mon, 05 Aug 2019 11:04:48 GMT</pubDate></item></channel></rss>
