    I cannot upload anything on my M5Stack Fire
    6 Posts 4 Posters 13.6k Views 1 Watching
      ferrianf
      Hi, can anyone help me?!
      I cannot compile anything with the Arduino IDE, due to the the following message:
      Arduino:1.8.9 (Mac OS X), Scheda:"M5Stack-FIRE, Enabled, 921600, None"
      /Users/Fabrizio/Documents/Arduino/libraries/M5Stack-master/src/utility/Power.cpp: In member function 'void POWER::powerOFF()':
      /Users/Fabrizio/Documents/Arduino/libraries/M5Stack-master/src/utility/Power.cpp:360:35: error: 'ESP_SLEEP_WAKEUP_ALL' was not declared in this scope
      esp_sleep_disable_wakeup_source(ESP_SLEEP_WAKEUP_ALL);
      /Users/Fabrizio/Documents/Arduino/libraries/M5Stack-master/src/utility/Power.cpp:361:28: error: 'gpio_deep_sleep_hold_dis' was not declared in this scope
      gpio_deep_sleep_hold_dis();
      What is happening?
      I reinstalled the Silicon Labs drivers and the M5Stack library (version 0.2.8) but nothing changed...
      Thank you very much
      Fabrizio
        ajb2k3 @ferrianf
        @ferrianf your arduino install is missing the required librarys needed to compile the code.
          ferrianf
          @ajb2k3 I tried to reinstall Arduino IDE 1.8.9 and the library M5Stack, the only one included in my code but nothing changed, always the same error!
          Thank you for your help :(
            cepics
            Have you find a solution?
            same problem here...
            Arduino: 1.8.9 (Mac OS X), Board: "M5Stack-Core-ESP32, QIO, 80MHz, Default, 921600, None"
            Invalid library found in /Users/bip/Documents/Arduino/hardware/espressif/esp32/libraries/AzureIoT: no headers files (.h) found in /Users/bip/Documents/Arduino/hardware/espressif/esp32/libraries/AzureIoT
            Invalid library found in /Users/bip/Documents/Arduino/hardware/espressif/esp32/libraries/BLE: no headers files (.h) found in /Users/bip/Documents/Arduino/hardware/espressif/esp32/libraries/BLE
            /Users/bip/Documents/Arduino/libraries/M5Stack/src/utility/Power.cpp: In member function 'void POWER::powerOFF()':
            /Users/bip/Documents/Arduino/libraries/M5Stack/src/utility/Power.cpp:361:28: error: 'gpio_deep_sleep_hold_dis' was not declared in this scope
             Used: /Users/bip/Documents/Arduino/hardware/espressif/esp32/libraries/SD
             Not used: /Users/bip/Documents/Arduino/libraries/SD
             Not used: /private/var/folders/f3/0kf10ljj6sj4q4twsw_vtxrw0000gn/T/AppTranslocation/A5F0A3E3-D38F-48FA-A88D-47CA921F1A87/d/Arduino-1.8.9.app/Contents/Java/libraries/SD
             Used: /Users/bip/Documents/Arduino/hardware/espressif/esp32/libraries/WiFi
             Not used: /private/var/folders/f3/0kf10ljj6sj4q4twsw_vtxrw0000gn/T/AppTranslocation/A5F0A3E3-D38F-48FA-A88D-47CA921F1A87/d/Arduino-1.8.9.app/Contents/Java/libraries/WiFi
            Multiple libraries were found for "SPI.h"
             Used: /Users/bip/Documents/Arduino/hardware/espressif/esp32/libraries/SPI
             Not used: /Users/bip/Documents/Arduino/libraries/SPI
            exit status 1
            tnks
              cepics
              solved on commenting out
              in
              I don't know why, but now arduino compile
              • raz0rsedgeR Offline
                raz0rsedge
                Getting same error on all my projects now, I think someting is broken.
