    no encoder readings..
    3.0k
    • C
      cepics
      Hi all, I'm trying to work with this incremental rotary encoder connected straight on GROVE port (no resistence), with this sketch:
      #include <M5Stack.h>
      float  XA_SIG = 0, XB_SIG = 1,  YA_SIG = 0, YB_SIG = 1;
      volatile float pulsesX, pulsesY;
        pinMode(22, INPUT_PULLUP); // internal pullup input pin
        pinMode(21, INPUT_PULLUP); // internalเป็น pullup input pin
        attachInterrupt(22, XA_RISE, RISING); // Pin 2 stack 22?
        attachInterrupt(21, XB_RISE, RISING); // Pin 3 stack 21?
        Serial.begin(115200);
        delay(100);
        Serial.println("Connected");
      }//setup
        Serial.print("x");
        Serial.print(pulsesX);
        Serial.println("end");
        delay(20);
      //X-Axis
      void XA_RISE() {
        detachInterrupt(22);
        //delay(1);
        XA_SIG = 1;
        if (XB_SIG == 0) {
          pulsesX++;//moving forward
        if (XB_SIG == 1) {
          pulsesX--;//moving reverse
        attachInterrupt(22, XA_FALL, FALLING);
      void XA_FALL() {
        //delay(1);
        XA_SIG = 0;
        if (XB_SIG == 1) {
        if (XB_SIG == 0) {
      void XB_RISE() {
        detachInterrupt(21);
        //delay(1);
        XB_SIG = 1;
        if (XA_SIG == 1) {
        if (XA_SIG == 0) {
        attachInterrupt(21, XB_FALL, FALLING);
      void XB_FALL() {
        //delay(1);
        XB_SIG = 0;
        if (XA_SIG == 0) {
        if (XA_SIG == 1) {
      but, when I touch the encoder I have no readings on serial monitor..
      x0.00end
      x0.00end
      x0.00end
      x0.00end
      x0.00end
      x0.00end
      x0.00end
      x0.00end
      x0.00end
      x0.00end
      x0.00end
      x0.00end
      x0.00end
      x0.00end
      x0.00end
      x0.00end
      x0.00end
      x0.00end
      x0.00end
      x0.00end
      x0.00end
      x0.00end
      x0.00end
      x0.00end
      whats wrong??
      maybe something about IRAM_ATTR ISR() ??
      tnks
      • C
        cepics
        nobody??
