Burn Ui Flow Firmware
I have just received a M5StickC and am trying to install stickC 1.3.2 uiflow firmware and I get the following error -
A fatal error occurred: Timed out waiting for packet header
I have checked the Comm port and baud rate is correct because the erase in M5Burner worked correctly. There is an old forum post about adding a capacitor between RST and GRD, is this still necessary? -
if you tried with 115200, and no success, that would be necessary.
