    Problems compiling example M5stack with arduino ide
    4.9k
    • P
      Powersoft
      The M5STACK is new for me. After installing the software and start an example I get the next errors :
      /Users/jankromhout/Documents/Arduino/libraries/M5Stack/src/LoRaWan.cpp: In member function 'void LoRaWanClass::init()':
      /Users/jankromhout/Documents/Arduino/libraries/M5Stack/src/LoRaWan.cpp:45:5: error: 'Serial2' was not declared in this scope
      Serial2.begin(9600, SERIAL_8N1, 16, 17);
      In file included from /Users/jankromhout/Documents/Arduino/libraries/M5Stack/src/LoRaWan.cpp:33:0:
      /Users/jankromhout/Documents/Arduino/libraries/M5Stack/src/LoRaWan.cpp: In member function 'void LoRaWanClass::getVersion(char*, short int, unsigned char)':
      /Users/jankromhout/Documents/Arduino/libraries/M5Stack/src/LoRaWan.h:33:29: error: 'Serial2' was not declared in this scope
      #define SerialLoRa Serial2
      Wat do I missing?
      Thanks for any help.
      Cheers, Jan
        ajb2k3 @Powersoft
        @powersoft remove #
        • P
          Powersoft
          Found the solution. a New clean install with the latest version. Now it's compiles well !
