    M5StickC Nixie tube Clock
    PROJECTS
    8
    28
    114.2k
      macsbug
      I made a Nixie tube clock with M5StickC.
      Creation date: 2019.06.06
      Creator: macsbug
      blog:https://macsbug.wordpress.com/2019/06/06/m5stickc-nixie-tube-clock/
      The original author of the following three articles is macsbug.
      1 . M5Stack Community / PROJECTS:
      Nixie tube watch simulated on M5Stick-C
      http://forum.m5stack.com/topic/1085/nixie-tube-watch-simulated-on-m5stick-
      2 . hackster.io:Nixie Tube Watch Simulated on ESP32 Using the M5Stick
      https://www.hackster.io/McOrts/nixie-tube-watch-simulated-on-esp32-using-the-m5stick-7ab9d9
      3 . McOrts/M5StickC_Nixie_tube_Clock:jun 17,2019
      https://github.com/McOrts/M5StickC_Nixie_tube_Clock
      • lukasmaximusL
        Thanks for sharing all these super cool projects with us @macsbug Would you be interested in putting some of these on our hackster.io https://m5stack.hackster.io/ if you don't have the time or are not confident with English we can post some of these for you on the hackster page and then attribute you as the author if we can have your permission.
        • SkinkS
          Skink
          I downloaded the program here : "https://github.com/McOrts/M5StickC_Nixie_tube_Clock" and installed it via Arduino.
          But with me comes only the following error message see picture and the clock does not work.
          What am I doing wrong or what is missing !
            ajb2k3 @Skink
            @skink looks like you don't have all the libraries installed.
            • SkinkS
              Skink
              Arduino: 1.8.9 (Windows 10), Board: "M5Stick-C, Default, 115200, None"
              In file included from C:\Users\Reiner St�hler\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\cores\esp32/Print.h:27:0,
                               from C:\Users\Reiner St�hler\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\cores\esp32/Stream.h:26,
                               from C:\Users\Reiner St�hler\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\libraries\Wire\src/Wire.h:31,
                               from C:\Users\Reiner St�hler\Documents\Arduino\libraries\M5StickC\src/M5StickC.h:67,
                               from sketch\vfd_18x34.c:3:
              C:\Users\Reiner St�hler\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\cores\esp32/Printable.h:25:1: error: unknown type name 'class'
               class Print;
              C:\Users\Reiner St�hler\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\cores\esp32/Printable.h:33:1: error: unknown type name 'class'
               class Printable
              C:\Users\Reiner St�hler\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\cores\esp32/Printable.h:34:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
              In file included from C:\Users\Reiner St�hler\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\cores\esp32/Stream.h:26:0,
              C:\Users\Reiner St�hler\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\cores\esp32/Print.h:34:1: error: unknown type name 'class'
               class Print
              C:\Users\Reiner St�hler\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\cores\esp32/Print.h:35:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
              In file included from C:\Users\Reiner St�hler\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\libraries\Wire\src/Wire.h:31:0,
              C:\Users\Reiner St�hler\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\cores\esp32/Stream.h:38:1: error: unknown type name 'class'
               class Stream: public Print
              C:\Users\Reiner St�hler\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\cores\esp32/Stream.h:38:13: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
              In file included from C:\Users\Reiner St�hler\Documents\Arduino\libraries\M5StickC\src/M5StickC.h:67:0,
              C:\Users\Reiner St�hler\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\libraries\Wire\src/Wire.h:38:1: error: unknown type name 'class'
               class TwoWire: public Stream
              C:\Users\Reiner St�hler\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\libraries\Wire\src/Wire.h:38:14: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
              C:\Users\Reiner St�hler\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\libraries\Wire\src/Wire.h:136:8: error: unknown type name 'TwoWire'
               extern TwoWire Wire;
              C:\Users\Reiner St�hler\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\libraries\Wire\src/Wire.h:137:8: error: unknown type name 'TwoWire'
               extern TwoWire Wire1;
              In file included from C:\Users\Reiner St�hler\Documents\Arduino\libraries\M5StickC\src/M5StickC.h:68:0,
              C:\Users\Reiner St�hler\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\libraries\SPI\src/SPI.h:28:1: error: unknown type name 'class'
               class SPISettings
              C:\Users\Reiner St�hler\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\libraries\SPI\src/SPI.h:29:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
              C:\Users\Reiner St�hler\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\libraries\SPI\src/SPI.h:38:1: error: unknown type name 'class'
               class SPIClass
              C:\Users\Reiner St�hler\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\libraries\SPI\src/SPI.h:39:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
              C:\Users\Reiner St�hler\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\libraries\SPI\src/SPI.h:86:8: error: unknown type name 'SPIClass'
               extern SPIClass SPI;
              In file included from C:\Users\Reiner St�hler\Documents\Arduino\libraries\M5StickC\src/M5Display.h:5:0,
                               from C:\Users\Reiner St�hler\Documents\Arduino\libraries\M5StickC\src/M5StickC.h:69,
              C:\Users\Reiner St�hler\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\libraries\FS\src/FS.h:24:18: fatal error: memory: No such file or directory
              compilation terminated.
              exit status 1
              Fehler beim Kompilieren für das Board M5Stick-C.
              Where are the libraries are must Install ??
              greetings skink
                I need to see a screen shot of the beginning of the sketch with the Include lines please.
                • SkinkS
                  Skink
                  Hello and thank you very much, here is the screenshot for you. M5Stickc is installed according to the M5stack manual: "https://docs.m5stack.com/#/en/quick_start/m5stickc/m5stickc_quick_start_with_arduino_Windows" and both files are loaded automatically when I load the "M5StickC_Nixie_tube_Clock.ino".
                  Don't understand why this doesn't work, so it's in the description of the Nixi Clock !!
                  Greetings skink
                  • grelmG
                    grelm
                    Without wanting to anticipate @ajb2k3 :
                    Your first screenshot says "Fehler beim Kompilieren für das Board ESP32 Pico Kit" and this board is also listed in the lower right corner of the screenshot.
                    I think, that you should first change the board-Type in the Arduino IDE under 'Tools/Werkzeuge' - 'Board/???' - .... to: 'M5Stick-C' and than try to compile again.
                    May be (and I hope) it helps ...
                    Programming M5Stack Fire with Arduino for Home Automation
                    SkinkS 1 Reply Last reply Reply Quote 1
                    • SkinkS
                      Skink @grelm
                      @grelm
                      0_1564920326669_Nixi.jpg Hello,
                      unfortunately no, I reinstalled everything and now I'm using M5Stick-C and also the transfer parameters are correct but it doesn't happen at all.
                      I'm really helpless what's missing or why he can't compile ???????
                        ajb2k3 @Skink
                        @skink said in M5StickC Nixie tube Clock:
                        Grus skink
                        When you change something like adding library you need to restart arduino
                        Try upload speed 150000 as that was what mine was set to when I installed it.
                        BTW are you suing the provided black usb cable?
                        • SkinkS
                          Skink @ajb2k3
                          @ajb2k3 Hello @all,
                          I've done everything like this, I also have a few more library´s.
                          But the program doesn't want to run on the M5Stick-C.
                          It is always only shown to me that an error occurred during compiling for the board M5Stick-C.
                          The program stops and that was it.
                          Means I don't get the program complicated at all, so I didn't even install it.
                          Can someone send me the link to the program again or send me a copy.
                          I am really in despair, because all examples from the Arduino environment for the M5Stick-C can be installed and run problem-free!
                          Greetings Skink
                          • grelmG
                            grelm
                            If @ajb2k3's suggestion didn't help, you could look into this:
                            I am not sure, but did you this: (from: https://github.com/McOrts/M5StickC_Nixie_tube_Clock)
                            Update Nixie Tube images
                            Execute the lcd-image-converter.exe include in this repository.
                            " Png or Jpg is read from File->Open Menu. The image will be displayed when loaded.
                            Select: Option->Conversions Menu. The top Preset: selects "Color R5G6B5".
                            Select: Image tap and select “8 bit” for Block size :. Press "OK".
                            The example "vfd_35x67_8.c" is output by "Convert ..." in File-Convert Menu. Know in advance the destination path. Tick: Import All Images You can also output all the images with “Convert ... all”.
                            Edit .c converted file. You will get an error as it is, so fix it with your editor.
                            " Change: "Static const uint8_t image_data_vfd_35x67 [4690] = {" at the top of the file deleting "image_data_" as result of "static const uint8_t vfd_35x67_8 [4690] = {".
                            At the bottom of delete de entire line: "const tImage vfd_35x67 = {image_data_vfd_35x67, 35, 67, 8};
                            Save the example "vfd_35x67_8".c***
                            May be you could send us the complete compiler-error-listing again, as the board-selection is correct now.
                            (Btw: as I don't have a M5Stick-C, i can not check even my own suggestions!)
                              I'm not sure what could be wrong as I have just compiled it
                              #include <M5StickC.h>
                              #include "vfd_18x34.c"
                              #include "vfd_35x67.c"
                              RTC_TimeTypeDef RTC_TimeStruct;
                              RTC_DateTypeDef RTC_DateStruct;
                              int mode_ = 3; // 3:2Lines 2: 2Lines(YYMM), 1:1Line
                              const uint8_t*n[] = { // vfd font 18x34
                                vfd_18x34_0,vfd_18x34_1,vfd_18x34_2,vfd_18x34_3,vfd_18x34_4,
                                vfd_18x34_5,vfd_18x34_6,vfd_18x34_7,vfd_18x34_8,vfd_18x34_9
                              const uint8_t*m[] = { // vfd font 35x67
                                vfd_35x67_0,vfd_35x67_1,vfd_35x67_2,vfd_35x67_3,vfd_35x67_4,
                                vfd_35x67_5,vfd_35x67_6,vfd_35x67_7,vfd_35x67_8,vfd_35x67_9
                              const char *monthName[12] = {
                                "Jan", "Feb", "Mar", "Apr", "May", "Jun",
                                "Jul", "Aug", "Sep", "Oct", "Nov", "Dec"
                              void setup(void){
                                pinMode(M5_BUTTON_HOME, INPUT);
                                M5.Lcd.fillScreen(BLACK);
                                M5.Lcd.setRotation(1);
                                M5.Axp.ScreenBreath(10);             // 7-15
                                // rtc setup start ---------------------------------------------
                                String pt = (__DATE__ " " __TIME__); // PC DATE TIME READ
                                //000000000011111111112  Read data
                                //012345678901234567890
                                //Jun  6 2019 07:20:41
                                char m1[3]; int  m2; // Month conversion ( Jun to 6 )
                                (pt.substring(0,3)).toCharArray(m1,4);
                                for (int mx = 0; mx < 12; mx ++) {
                                  if (strcmp(m1, monthName[mx]) == 0){m2 = mx + 1; break;}
                                RTC_DateTypeDef DateStruct;         // Month, Date, Year
                                DateStruct.Month   = m2;
                                DateStruct.Date    = (pt.substring(4, 6)).toInt();
                                DateStruct.Year    = (pt.substring(7,11)).toInt();
                                M5.Rtc.SetData(&DateStruct);
                                RTC_TimeTypeDef TimeStruct;         // Hours, Minutes, Seconds
                                TimeStruct.Hours   = (pt.substring(12,14)).toInt();
                                TimeStruct.Minutes = (pt.substring(15,17)).toInt();
                                TimeStruct.Seconds = (pt.substring(18,20)).toInt();
                                M5.Rtc.SetTime(&TimeStruct);
                                // rtc setup end -----------------------------------------------
                              void loop(void){
                                if(digitalRead(M5_BUTTON_HOME) == LOW){
                                  if (mode_ == 3){mode_ = 1;M5.Lcd.fillScreen(BLACK);return;}
                                  if (mode_ == 2){mode_ = 3;M5.Lcd.fillScreen(BLACK);return;}
                                  if (mode_ == 1){mode_ = 2;M5.Lcd.fillScreen(BLACK);return;}
                                if ( mode_ == 3 ){ vfd_3_line();}   // hh,mm,ss
                                if ( mode_ == 2 ){ vfd_2_line();}   // yyyy,mm,dd,hh,mm,ss
                                if ( mode_ == 1 ){ vfd_1_line();}   // mm,ss
                                delay(500);
                              void vfd_3_line(){
                                M5.Rtc.GetTime(&RTC_TimeStruct);
                                M5.Rtc.GetData(&RTC_DateStruct);
                                int h1 = int(RTC_TimeStruct.Hours / 10 );
                                int h2 = int(RTC_TimeStruct.Hours - h1*10 );
                                int i1 = int(RTC_TimeStruct.Minutes / 10 );
                                int i2 = int(RTC_TimeStruct.Minutes - i1*10 );
                                int s1 = int(RTC_TimeStruct.Seconds / 10 );
                                int s2 = int(RTC_TimeStruct.Seconds - s1*10 );
                                M5.Lcd.pushImage(  2,0,35,67, (uint16_t *)m[h1]);
                                M5.Lcd.pushImage( 41,0,35,67, (uint16_t *)m[h2]);
                                M5.Lcd.drawPixel( 79,22, ORANGE); M5.Lcd.drawPixel( 79,48,ORANGE);
                                M5.Lcd.drawPixel( 79,21, YELLOW); M5.Lcd.drawPixel( 79,47,YELLOW);
                                M5.Lcd.pushImage( 83,0,35,67, (uint16_t *)m[i1]);
                                M5.Lcd.pushImage(121,0,35,67, (uint16_t *)m[i2]);
                                M5.Lcd.pushImage(120,45,18,34, (uint16_t *)n[s1]);
                                M5.Lcd.pushImage(140,45,18,34, (uint16_t *)n[s2]);
                                if ( s1 == 0 && s2 == 0 ){ fade();}
                              void vfd_2_line(){
                                //Serial.printf("Data: %04d-%02d-%02d\n",RTC_DateStruct.Year,RTC_DateStruct.Month,RTC_DateStruct.Date);
                                //Serial.printf("Week: %d\n",RTC_DateStruct.WeekDay);
                                //Serial.printf("Time: %02d : %02d : %02d\n",RTC_TimeStruct.Hours,RTC_TimeStruct.Minutes,RTC_TimeStruct.Seconds);
                                // Data: 2019-06-06
                                // Week: 0
                                // Time: 09 : 55 : 26
                                int y1 = int(RTC_DateStruct.Year    / 1000 );
                                int y2 = int((RTC_DateStruct.Year   - y1*1000 ) / 100 );
                                int y3 = int((RTC_DateStruct.Year   - y1*1000 - y2*100 ) / 10 );
                                int y4 = int(RTC_DateStruct.Year    - y1*1000 - y2*100 - y3*10 );
                                int j1 = int(RTC_DateStruct.Month   / 10);
                                int j2 = int(RTC_DateStruct.Month   - j1*10 );
                                int d1 = int(RTC_DateStruct.Date    / 10 );
                                int d2 = int(RTC_DateStruct.Date    - d1*10 );
                                int h1 = int(RTC_TimeStruct.Hours   / 10) ;
                                M5.Lcd.pushImage(  0, 0,18,34, (uint16_t *)n[y1]);
                                M5.Lcd.pushImage( 19, 0,18,34, (uint16_t *)n[y2]);
                                M5.Lcd.pushImage( 38, 0,18,34, (uint16_t *)n[y3]);
                                M5.Lcd.pushImage( 57, 0,18,34, (uint16_t *)n[y4]);
                                M5.Lcd.drawPixel( 77,13, ORANGE); M5.Lcd.drawPixel( 77,23,ORANGE);
                                M5.Lcd.pushImage( 80, 0,18,34, (uint16_t *)n[j1]);
                                M5.Lcd.pushImage( 99, 0,18,34, (uint16_t *)n[j2]);
                                M5.Lcd.drawPixel(118,13, ORANGE); M5.Lcd.drawPixel(119,23,ORANGE);
                                M5.Lcd.pushImage(120, 0,18,34, (uint16_t *)n[d1]);
                                M5.Lcd.pushImage(140, 0,18,34, (uint16_t *)n[d2]);
                                M5.Lcd.pushImage( 00,40,18,34, (uint16_t *)n[h1]);
                                M5.Lcd.pushImage( 20,40,18,34, (uint16_t *)n[h2]);
                                M5.Lcd.drawPixel( 48,54, ORANGE); M5.Lcd.drawPixel( 48,64,ORANGE);
                                M5.Lcd.pushImage( 60,40,18,34, (uint16_t *)n[i1]);
                                M5.Lcd.pushImage( 80,40,18,34, (uint16_t *)n[i2]);
                                M5.Lcd.drawPixel(108,54, ORANGE); M5.Lcd.drawPixel(108,64,ORANGE);
                                M5.Lcd.pushImage(120,40,18,34, (uint16_t *)n[s1]);
                                M5.Lcd.pushImage(140,40,18,34, (uint16_t *)n[s2]);
                                if ( i1 == 0 && i2 == 0 ){ fade();}
                              void vfd_1_line(){
                                M5.Lcd.pushImage(  2,6,35,67, (uint16_t *)m[i1]);
                                M5.Lcd.pushImage( 41,6,35,67, (uint16_t *)m[i2]);
                                M5.Lcd.drawPixel( 79,28, ORANGE); M5.Lcd.drawPixel( 79,54,ORANGE);
                                M5.Lcd.drawPixel( 79,27, YELLOW); M5.Lcd.drawPixel( 79,53,YELLOW);
                                M5.Lcd.pushImage( 83,6,35,67, (uint16_t *)m[s1]);
                                M5.Lcd.pushImage(121,6,35,67, (uint16_t *)m[s2]);
                              void fade(){
                                for (int i=7;i<16;i++){M5.Axp.ScreenBreath(i);delay(25);}
                                for (int i=15;i>7;i--){M5.Axp.ScreenBreath(i);delay(25);}
                                M5.Axp.ScreenBreath(12);
                              I'm using Arduino 1.8.9 to compile fresh from github.
                              Have you tried updating your M5Stack vfd Libraries?
                              it looks like you libs are 1.0.2 where as I am using 1.22
                              • SkinkS
                                Skink
                                Thank you @ajb2k3 ,
                                The program is now compiled and transferred.Thank you for the Link
                                Afterwards the time appears for one second when resetting the M5Stick-C, then the screen is black.
                                @ajb2k3 yes the lib is 1.22 which I use too!
                                Mh something I still do wrong.
                                greeting skink
                                  ajb2k3 @Skink
                                  @skink is the battery in the M5Stick fully charged?
                                  Plug the stick into a wall charger and leave it for a few hours.
                                  • SkinkS
                                    Skink @ajb2k3
                                    the battery is full, even if I leave the M5Stick-C connected to the laptop, the Nixi clock disappears after a second and the screen stays black, but you can still see the backlight.
                                    What I haven't understood about the manual so far is the following part:
                                    When I load the file M5StickC-Nixie-tube_clock.ino into Arduino, both files vfd_1834.c and vfd_3567.c are loaded automatically.
                                    Where or what should I change !
                                    Don't understand this !
                                    Greetings Reiner
                                      ajb2k3 @Skink
                                      @skink I'm not sure as i just down loaded and compiled/flash strait to the stick c.
                                      one thing to try is to download m5burner, wipe and install uiflow. the try re compiling and uploading in arduino.
                                      is it only the nixi tube demo doing this?
                                      • SkinkS
                                        Skink @ajb2k3
                                        @ajb2k3 Yes it is only with the Nixi Tube demo, all other examples from the Arduino application run without problems.
                                        Just started UI-Flow Desktop application and install UIFlow-v1.3.4 beta with M5Burner now.
                                        And then I will install the Nixi Clock again by Arduino software.
                                        Unfortunately we don't see any success with UIFlow-v1.3.5 beta.
                                        Yes, the problem only occurs during the Nixi tube demo.
                                        If something is missing at Arduino or like already ajb2k3 writes maybe it is due to the libs 1.0.2 how do I install the 1.22 ???
                                        Maybe it works then.
                                        Too bad you always see it for a second and the Nixi clock looks really awesome.
                                        Greetings Reiner
                                          ajb2k3 @Skink
                                          @skink All you are doing is using UIFlow to clear the program storage space on the M5Stack. I'm confused because my stick C is working as it should and not showing a blank screen after a few seconds.
                                          • SkinkS
                                            Skink @ajb2k3
                                            Well, I'm afraid I don't know any more advice either. Try to attach a video, if possible.
                                            This is what it looks like in any case, I only deleted the memory with M5 Stack Burner and then played the Nixi Clock with Arduino, the same result unfortunately!
                                            Greetings Reiner
                                            P.S. Unfortunately I don't have the possibility to upload a video here. Too bad
