[Solved]How to use interruption processing in m5stack
I want to make a simple game.
When you pressed button of m5stack, how did you move other function?
There is not other function in roop().I use Arduino1.8.9. -
@tkb-koki Do you means how to use BUTTON on M5Stack Core?
If I am right, you can refer to the code blow.
https://github.com/m5stack/M5Stack/tree/master/examples/Basics
/* Name: button.ino Created: 2018/9/21 14:06:15 Author: sakabin */ #include <M5Stack.h> // The setup() function runs once each time the micro-controller starts void setup() { // init lcd, serial, but don't init sd card M5.begin(true, false, true); M5.Lcd.clear(BLACK); M5.Lcd.setTextColor(YELLOW); M5.Lcd.setTextSize(2); M5.Lcd.setCursor(65, 10); M5.Lcd.println("Button example"); M5.Lcd.setCursor(3, 35); M5.Lcd.println("Press button B for 700ms"); M5.Lcd.println("to clear screen."); M5.Lcd.setTextColor(RED); } // Add the main program code into the continuous loop() function void loop() { M5.update(); // if you want to use Releasefor("was released for"), use .wasReleasefor(int time) below if (M5.BtnA.wasReleased()) { M5.Lcd.print('A'); } else if (M5.BtnB.wasReleased()) { M5.Lcd.print('B'); } else if (M5.BtnC.wasReleased()) { M5.Lcd.print('C'); } else if (M5.BtnB.wasReleasefor(700)) { M5.Lcd.clear(BLACK); M5.Lcd.setCursor(0, 0); } } © 2019 GitHub, In -
@m5-docs No, i was able to use BUTTON.
I want to use other function while executing "delay();". -
@tkb-koki What programming system are you using?
In UIFlow you have a series of loops including loops dedicated to just the three buttons on the front. -
@tkb-koki multi-Progress?
@ajb2k3 I am using Arduino IDE.
@m5-docs not multi. I want to use interruption processing.
