    [Solved]M5stack core not recognizing Button Unit correctly
    12 Posts 3 Posters 21.9k Views 1 Watching
      The black doesn't have a port B which is the issue, on the black you need to use the A0 pin on the base.
      The black only has the red port which doesn't work.
      • L Offline
        LastCaress
        But it still recognizes the ButtonA as a unit press :| Also, can't I use the bottom with the Port B & C ?
          ajb2k3 @LastCaress
          @lastcaress The Button unit is not the same as button A, B and, C
          You have the go base?
          Then yes it works on Port B however Units seem to be unselectable at the moment.
            @LastCaress Buttons A, B and, C use the event button loop and obtain button (Yellow blocks)
            Button units use a lightgreen block.(just using blocky for example)
            • L Offline
              LastCaress
              Black works with port B:
              alt text
              • L Offline
                LastCaress
                When coding in grey : Wait for press of UNIT button, works, no problem
                When coding in black : Wait for press of UNIT button, doesn't work. If press button A, it thinks it was a press by UNIT button
                • L Offline
                  LastCaress @LastCaress
                  Reading pin 36 on the black cores is not possible right now. Please fix, thank you.
                  • m5-docsM Offline
                    m5-docs
                    Hello @LastCaress
                    The hardware file if BLACK is same as GRAY expect that GRAY OWNS mpu9250.
                    So if the BUTTON Unit works weith GRAY, it wil also work with BLACK.
                    You can check the G36 on BLACK by reading the level of G36 after G36 attached to 3.3V pin.
                    M5Stack documentation URL
                    https://docs.m5stack.com
                    • L Offline
                      LastCaress
                      Simple test, 4 units, two grey, two black, using the same portB and button add on:
                      alt text
                      and it is working now. Did you update the flow?
                      • m5-docsM Offline
                        m5-docs
                        @LastCaress Maybe it has been updated. UIFlow is updated everyday.
