    [Solved]M5stack core not recognizing Button Unit correctly
    12 Posts 3 Posters 21.9k Views 1 Watching
    • L Offline
      LastCaress
      Ok, this is a problem with the m5stack core (black). I tried in two different ones, and they had the same problem. Then I tried in two greys and they did not have the problem. Please fix this.
        The black doesn't have a port B which is the issue, on the black you need to use the A0 pin on the base.
        The black only has the red port which doesn't work.
        • L Offline
          LastCaress
          But it still recognizes the ButtonA as a unit press :| Also, can't I use the bottom with the Port B & C ?
            ajb2k3 @LastCaress
            @lastcaress The Button unit is not the same as button A, B and, C
            You have the go base?
            Then yes it works on Port B however Units seem to be unselectable at the moment.
              @LastCaress Buttons A, B and, C use the event button loop and obtain button (Yellow blocks)
              Button units use a lightgreen block.(just using blocky for example)
              • L Offline
                LastCaress
                Black works with port B:
                alt text
                • L Offline
                  LastCaress
                  When coding in grey : Wait for press of UNIT button, works, no problem
                  When coding in black : Wait for press of UNIT button, doesn't work. If press button A, it thinks it was a press by UNIT button
                  • L Offline
                    LastCaress @LastCaress
                    Reading pin 36 on the black cores is not possible right now. Please fix, thank you.
                    • m5-docsM Offline
                      m5-docs
                      Hello @LastCaress
                      The hardware file if BLACK is same as GRAY expect that GRAY OWNS mpu9250.
                      So if the BUTTON Unit works weith GRAY, it wil also work with BLACK.
                      You can check the G36 on BLACK by reading the level of G36 after G36 attached to 3.3V pin.
                      M5Stack documentation URL
                      https://docs.m5stack.com
                      • L Offline
                        LastCaress
                        Simple test, 4 units, two grey, two black, using the same portB and button add on:
                        alt text
                        and it is working now. Did you update the flow?
                        • m5-docsM Offline
                          m5-docs
                          @LastCaress Maybe it has been updated. UIFlow is updated everyday.
