    How to use GPS module with SIM800L Module?
    Modules
    16.0k
    • P
      poydevelop
      I can't find the document. help me please.
      • T
        tkl
        Change the pins for the GPS module as follows (by cutting the existing bridge and re-soldering). Only downside is, that the Serial monitor/output is not available anymore
        • RXD: 1
        • TXD: 3
        • PPS (not connected)
        Now, you can use the GPS module on the serial port 0:
        // The TinyGPS++ object
        TinyGPSPlus gps;
        // The serial connection to the GPS device
        HardwareSerial gps_serial(0);
        gps_serial(GPSBaud);
        // ... (within a loop/smart delay)
        while (gps_serial.available())
            gps.encode(gps_serial.read());
        For the SIM800L you can use the regular configuration without changing anything:
        #define SerialAT Serial2
        TinyGsm modem(SerialAT);
        TinyGsmClient client(modem);
        • P
          poydevelop
          Thx sir.
          • P
            poydevelop
            esptool.py v2.6-beta1
            Serial port COM3
            Connecting......................................_____
            A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header
            • m5-docsM
              m5-docs @poydevelop
              @poydevelop Try to clean the flash
              M5Stack documentation URL
              https://docs.m5stack.com
              • P
                poydevelop
                how to cutting the existing bridge?
                • P
                  poydevelop @poydevelop
                  I re-soldering RX-1 and TX-3. is it correct?
                  • m5-docsM
                    m5-docs @poydevelop
                    @poydevelop Need to cut the two lines which are RX-17, TX-16 with a knife first, then re-sold RX-1, TX-3
                    • P
                      poydevelop @m5-docs
                      Thank you sir, knife it work.
