    M5Stack CoreS3 SE + COMMU display problem when replugging USB
    4 Posts 2 Posters 1.8k Views
      frank_b
      hi
      i have a weird problem with the CoreS3 SE + COMMU. i have some RS485 device and data coming on a UART configured to the CoreS3 port (next to the USB-C connector). data is displayed/updated on the screen. during (arduino) development all worked fine. flashing code over USB automatically restarts the code and i have a nice display updating every second.
      but i found out that not flashing the CoreS3 and just connecting USB-C for power (and logging) i get a somewhat scrambled display.
      i have chatted quite a bit with the M5Stack AI chat but it is still not fixed. everytime i just connect USB-C it is a bit scrambled. re-flashing the same code give a nice and clean display. what is going on??
      my initialization code is (most of it suggested by M5Stack AI):
          auto cfg = M5.config();
          cfg.internal_imu = false;
          cfg.internal_mic = false;
          cfg.clear_display = true; // Ensure display is cleared during init
          // Initialize M5 with proper power sequencing
          M5.begin(cfg);
          // Explicitly reset the AW9523 IO expander that controls display power
          Wire.begin(11, 12); // CoreS3 internal I2C bus pins
          Wire.beginTransmission(0x58); // AW9523 address
          Wire.write(0x00); // Reset register
          Wire.write(0x00); // Perform hardware reset
          Wire.endTransmission();
          delay(100);
          // Re-initialize display with full reset
          M5.Display.init();
          M5.Display.setBrightness(128);
          M5.Display.fillScreen(TFT_BLACK);
          M5.Display.display();
      the wire command actually give errors so i do not think it is doing anything:
      E (3570) i2c.master: I2C transaction unexpected nack detected
      E (3571) i2c.master: s_i2c_synchronous_transaction(945): I2C transaction failed
      E (3572) i2c.master: i2c_master_multi_buffer_transmit(1207): I2C transaction failed
      here is a "scrambled" picture:
      and this after reflash:
      help?!
        felmue @frank_b
        Hello @frank_b
        have you tired without COMMU module stacked?
          frank_b @felmue
          @felmue thanks for your message: i also had the "din base" and the "lan module" connected (but not used). disconnecting the lan module fixes the problem!!
            frank_b @frank_b
            it was caused by the CS of the LAN Module13.2. switching the jumper to the alternate position fixed the problem...
            so far these seem to work (CoreS3 SE+COMMU+Lan Module13.2+DIN Base):
            int  cs_pin  = 13; // jumper right
            int rst_pin = 0; // jumper left
            int  int_pin = 10;// jumper left
