    4 Relay Card Failure
    1 Posts 1 Posters 533 Views
      SirMichael
      I have an M5Stack, Core2 AWS and a 4 relay card
      I use it to switch remote antenna relays from my LDMOS amplifier project. When ever a different band is selected, the relays (12v signal) change the antenna on the remote switch (at the base of the tower).
      I had this running in my project for months, working OK, then suddenly it stopped working. No error messages. HOWEVER after a couple days I started getting the "4RELAY INIT ERROR" message from the init code:
      // Setup the Antenna Band Output Relays:
        if (!RELAY.begin(&Wire1, MODULE_4RELAY_ADDR, 21, 22, 200000L)) {
          dbprint("4RELAY INIT ERROR");
          PlayWav(RlyErr);
          M5.delay(2000);
      I purchased a replacement relay card and installed it (jumpers are setup identically to what I had) but it didn't work! So then I put in a new M5Stack Core2 AWS, loaded in the Arduino program and still it doesn't work!!!
      Any suggestions? I'm at a loss...
      Sir Michael
