    PPS module and touchscreen
    3 Posts 2 Posters 863 Views
    • B Offline
      BruderTom
      I try to use a PPS 13.2 module with a CoreS3-SE and want to adjust its output voltage via touchscreen. I use C++ in platformIO. I can get the PPS to work properly and I can get the touchscreen to work, but I can't do both together. I tried many different ways. For reference I tried this simplified code:
      #include <M5Unified.h>
      #include "M5ModulePPS.h"
      M5GFX display;
      M5ModulePPS pps;
        // Button zeichnen
        M5.Display.fillScreen(TFT_BLACK);
        M5.Display.fillRoundRect(60, 80, 200, 120, 15, TFT_BLUE);
        while (!pps.begin(&Wire, M5.In_I2C.getSDA(), M5.In_I2C.getSCL(), MODULE_POWER_ADDR, 1000000U));
        pps.setOutputVoltage(1.0);
        pps.setOutputCurrent(0.5);
        pps.setPowerEnable(true);
        uint32_t ms = millis();
        static uint32_t last_ms = ms;
        static float OutputVoltage = 1.0;
        M5.update();
        if (M5.Touch.getCount() > 0) {
          auto t = M5.Touch.getDetail();
          if (t.x>=60 && t.x<=260 && t.y>=80 && t.y<=200) {
            M5.Display.fillRoundRect(60, 80, 200, 120, 15, TFT_RED);
            pps.setOutputVoltage(0);
        if(ms-last_ms>1000)
          OutputVoltage += 0.1;
          pps.setOutputVoltage(OutputVoltage);
          last_ms = ms;
      The touch works (although laggy), but the PPS doesn't update its output voltage. If I remove the line M5.update(); the PPS works but obviously the touch doesn't. The PPS program in the M5Burner works (although also laggy) so it should be possible somehow.
      • felmueF Online
        felmue @BruderTom
        Hello @BruderTom
        the issue seems to be an I2C conflict. Internal I2C already uses Wire1; the PPS code initializes a second I2C instance (Wire) with the same GPIOs for SDA and SCL. The result is: both I2C instances (Wire and Wire1) fight against each other.
        Try replacing below line so the correct Wire1 instance is used for PPS as well:
        //  while (!pps.begin(&Wire, M5.In_I2C.getSDA(), M5.In_I2C.getSCL(), MODULE_POWER_ADDR, 1000000U));
          while (!pps.begin((M5.In_I2C.getPort() == I2C_NUM_1) ? &Wire1 : &Wire, M5.In_I2C.getSDA(), M5.In_I2C.getSCL(), MODULE_POWER_ADDR, 1000000U));
        • B Offline
          BruderTom @felmue
          @felmue That did it! Thanks a lot!
