    Cannot delete /replace python file in the filesystem
    UiFlow 2.0
    • T
      tom-test1
      Hi , I'm creating a custom block to talk to Firebase database.
      I found that I need to upload my custom python file to the filesystem "lib" directory, in order for it to work
      But, If I try to make a correction or update the file, I delete it and upload a new one, the old file still runs. it has not been deleted.
      Currently the workaround is to name the new file "filename2.py" instead of "filename.py" and this works - the new file runs.
      The only way to completely revert to original mode is to wipe all the flash.
      Is there a fix for this issue?
      Using UIFLOW2 with StickCPlus1.1, StickCplus2
      Thanks!
      • robskiR
        robski @tom-test1
        @tom-test1 have you tried to use "Thonny" to see and edit files?
        • T
          tom-test1 @robski
          @robski I wanted to create a simple flow for pupils that does not require more tools. it should be possible with the built in file manager, it seems like there is a bug , just wanted to know if there is a workaround
