    ImportError: no module named 'm5ui'
    UiFlow 2.0
    1.4k
    • K
      kirill271099
      У меня есть проблема, я обновил прошивку на устройстве cardputer, но вылезла ошибка ImportError: no module named 'm5ui', хотя этот модуль используется в документации. В чем может быть проблема?
      H robskiR 2 Replies Last reply Reply Quote 0
      • H
        h12616 @kirill271099
        @kirill271099 which board are you using? it would be easier if you can post in English so more people understand what you are saying.
        • robskiR
          robski @h12616
          @h12616 - cardputer
          • robskiR
            robski @kirill271099
            @kirill271099 said in ImportError: no module named 'm5ui':
            what firmware ver you updated your cardputer to?
            • H
              h12616 @robski
              @robski my understanding is that carputer does not support M5UI. you probably need a device with touchscreen like core2 to do that.
              • robskiR
                robski @h12616
                @h12616 you are correct not all M5 devices support M5UI - its not me btw its @kirill271099
