    StamPLC: Replace RTC battery?
    General
    • N
      nvko23
      Can you replace the RTC battery of StamPLC, if it is end-of-life?
        felmue @nvko23
        Hello @nvko23
        after opening my M5StamPLC I found that the RTC battery is located at the underside of the CPU board. It is soldered to the board. So yes, I'd say it is replaceable, but the proper soldering tools are required.
        BTW: the RTC battery in my M5StamPLC seems to be completely flat as I measure 0 volts.
        • J
          JosephSPuckett @felmue
          @felmue said in StamPLC: Replace RTC battery?:
          Hello @nvko23
          Thank you so much
