StamPLC: Replace RTC battery?
Can you replace the RTC battery of StamPLC, if it is end-of-life?
Hello @nvko23
after opening my M5StamPLC I found that the RTC battery is located at the underside of the CPU board. It is soldered to the board. So yes, I'd say it is replaceable, but the proper soldering tools are required.
BTW: the RTC battery in my M5StamPLC seems to be completely flat as I measure 0 volts.
Felix -
@felmue said in StamPLC: Replace RTC battery?:
Hello @nvko23
FelixThank you so much
Hello @nvko23 solitaired
FelixGreat, thanks you very good
