    使用ArduinoIDE编译Cardputer的示例代码,提示错误Error: missing data from bitq interface,如何解决?
    提问专区
    • W
      wingirl517
      Open On-Chip Debugger v0.12.0-esp32-20250422 (2025-04-22-13:02)
      Licensed under GNU GPL v2
      For bug reports, read
      http://openocd.org/doc/doxygen/bugs.html
      DEPRECATED! use 'gdb port', not 'gdb_port'
      DEPRECATED! use 'tcl port' not 'tcl_port'
      DEPRECATED! use 'telnet port', not 'telnet_port'
      CDRTOSConfigure
      Info : only one transport option; autoselecting 'jtag'
      Info : esp_usb_jtag: VID set to 0x303a and PID to 0x1001
      Info : esp_usb_jtag: capabilities descriptor set to 0x2000
      Info : Listening on port 50008 for tcl connections
      Info : Listening on port 50009 for telnet connections
      Info : esp_usb_jtag: serial (B0:81:84:96:9B:38)
      Info : esp_usb_jtag: Device found. Base speed 40000KHz, div range 1 to 255
      Info : clock speed 40000 kHz
      Error: libusb_bulk_write error: LIBUSB_ERROR_NOT_FOUND
      /Users/lily/Library/Arduino15/packages/m5stack/tools/openocd-esp32/v0.12.0-esp32-20250422-cn/bin/../share/openocd/scripts/target/esp_common.cfg:9: Error:
      File "/Users/lily/Library/Arduino15/packages/m5stack/tools/openocd-esp32/v0.12.0-esp32-20250422-cn/bin/../share/openocd/scripts/target/esp_common.cfg", line 9, in script
      • kurikoK
        kuriko @wingirl517
        @wingirl517
        具体是哪一个示例?
        • kurikoK
          kuriko
          @wingirl517
          看你这个问题压根不是编译的问题,你是不是在Arduino IDE里选了debug?你应该按左边那两个按钮的
